Anandtech's rampage formula article and my system
majorissuez
4
Not sure if this is the right section sorry if it isnt
Specs:
Intel Q9450 @3.6ghz stable w. Thermalright ultima-90 cooler
Corsair Dominator 2x2gb ddr2-8500 @ 1081mhz 5-5-5-15
1000w Antec Trupower Quattro
Asus Rampage formula
Xfx 8800gtx 640mb
My Fsb for my cpu is 450
What fsb Strap do i need to use and what Trd (MCH read delay) do i need to set in order for compatibility with my setup. are there anyother settings ive missed that i need to do what this article is talkign about?
thanks!
lopri
13,329
709
You are already under 333 strap with 5:6 divider. With 2GB sticks and 450FSB, you're likely to be at tRD=7 or 8 and that's as good as it gets with your setup. (Check the 'Performance Level' using Everest or MemSet)
JPB
4,064
89
Specs:
Xfx 8800gtx 640mb
thanks!
This is going to be the motherboard of my choice for my second build :)
Nice :thumbsup:
bryanW1995
11,144
32
nice, I'm at very similar settings that you have.
450x8 with tuniq
ballistix 2x1 pc8500 @ 1080 5-5-5-18
my trd with these settings with the 5:6 multiplier is 7. I used to run my e6750 at 425x8 but on the 4:5 multiplier with trd=6, it's just hard to get much better than 7 with that high of an fsb unfortunately :(
majorissuez
4
yeah alright im happy with 7 i get 47.2ns response time in Everest which is good i think
JPB: the Rampage formula is Awesome...its got everything i need and performs great
