Anandtech on IRC.. thats right.. #anandtech on EFNet !!
TheGizmo
3,627
Well guys.. I've always wondered why I haven't come across an anandtech irc channel.. so I figured what the hell, might as well start one up.. as of right now #anandtech on EFNet is open to you guys.. I have about 15 bots(thanks to hondaman, duckman, and links) or so in there, so it should work out pretty well. Talk about whatever.. hot deals, tech stuff.. etc.. just a place to hang out ya know?
here are some efnet servers: irc.webgiro.se | irc.easynews.com | irc.rt.ru | irc.prison.net
of course there are many others.. but theres a few to get you guys that don't know them on. Hey, even if theres not many people.. stick around, I'm hoping after a while we can get a bunch of us in there and always have a conversation going. See ya guys there.
-th3g1z
WhiteWonder
3,168
i think there is an official anandtech on irc, but i don't remember its location, i used to go there all the time.
i'll look for it
for some reason, my router doesn't like me to connect to any EF nets, or i guess it could be my cable.
errrrrr
dakata24
6,366
i'll look for it
errrrrr
i dont remember what server, but isnt it #neochat or something..
edit: [Homer] Doh! [/Homer] im slow..
WhiteWonder
3,168
Originally posted by: Millenium
#neochat on undernet is the anandtech channel.
there we go, undernet is the one that lets me connect
i'll go on to see if anyone remembers me
WhiteWonder
3,168
Originally posted by: y00ycdz
Neochat, why that name? I'm all for #anandtech on eFnet! :)
i would if i could, but i can never get onto eFnet, i get this msg
*** Banned: Install Identd for access (2001/4/18 09.20)
oh well, i'll just try to hax0r my way in!
y00ycdz
1,313
read my post up there some? Forward port 113 from you router to your computer. That should fix it.
WhiteWonder
3,168
yeah, i'v tried port forwarding, and it never seems to work
#neochat is the official anandtech channel, on undernet.
EFnet is as burdened as it is, we don't need these retards clogging it anymore.
TheGizmo
3,627
heh well you guys can be the offical.. unofficial as we are, but I won't go to undernet.. theres always room for a channel on another network.
MazerRackham
6,572
Here's a retarted question, but how do you even "use" these channels? I've always been confused by IRC, and all things related. Just tell me what software I need to use, and how I need to configure it ;)
Entity
10,090
I'd be there right now, but I can't figure out how to configure identd to run properly. It's running right now, but when I connect using BitchX, the servers report me as not having identd installed...anyone wanna help? Redhat 7.3...
Rob
y00ycdz
1,313
Lame? did you mean you're lame?
[21:41] (^Matt^) let me spam before I go
[21:41] (^Matt^) Operating System: /Windows 2000 Professional, Service Pack 2 (5.0 - 2195)\ º Uptime: /2d 19h 50m 32s\ º Record: /1wk 7hrs 31mins 42secs(Set on 03/07/02 using 2000)\
[21:41] (^Matt^) Memory Usage: /Usage: 177/512MB (34.57%)\ º /||||||||||--------------------\ º Display Info: /1024x768 32bit 100Hz\ º Monitor: /Plug and Play Monitor\
[21:41] (^Matt^) CPU Info: /1-AMD Thunderbird, 1410MHz, 256KB\ º Temperature: /Deactivated by user\
[21:41] (^Matt^) Hard Disks: /Total/Free: 113.6/44.64GB º Total/Free space on: C: 37.27GB/18.34GB º E: 68.36GB/18.95GB º F: 7.97GB/7.35GB\
[21:42] (^Matt^) Connection/Network Interfaces: /#1 (Intel(R) PRO Adapter (10Mb/s) 0.00MB In, 0.00MB Out) #2(WAN (PPP/SLIP) Interface (10Mb/s) 216.05MB In, 61.31MB Out)\
TheGizmo
3,627
*sigh* why does everyone have to rip on things when they are just getting started.. the channel of course isnt going to be filled less than an hour after the post, yeesh.. I don't know what your problem is matt.
