Analog Modem chatter over my dsl line??? Help Please
Spoon
I have ntelos dsl while Verizon maintains the lines. Over the past month I've been having a intermitent problem of Analog modem chatter over my phone lines. All the dsl filters are in place and the system has worked flawlessly for the last six months. I have called verizon and the continue to say that my lines are fine.
Could a neighbors wifi be causing this????
THe phone that Im trying to use is a Panasonic Spread Sprectrum
THe only way to correct the problem is to unplug everything and let the phone lines reset themselves
and no I have no analog modems installed anywhere, and the dsl continues to work fine while the chatter is present
thanks and any advice is appreciated
bozo1
6,364
How do you know it's modem chatter? Do you hear modem tones?
If so, call your telco and don't even mention that anything about 'chatter' or 'dsl' or 'cordless phones' or anything. Just tell them that 'sometimes' when you are talking on the phone you hear other peoples conversations and it is annoying and they should correct it.
