New install, ABit AN7 with AthXP3300
Bios is latest, Dated 3/24/04
Post code display was staying on 2.0. after full good boot.
Had two spontaneous shut downs last night while running Adope Photoshop Elements, building photo directory.
CPU temp per MBM5 is 53C--this appears to be too hot for no load, under load it's up to as much at 60C.
Post code now stops on 21--"HPM Initialisation, Notebook/Laptop mode---needless to say this is not a laptop.
Also it will cycle from 21 to 26---"
Task manager shows two processes that are running at 02 or 11 on the CPU: "svchost and system" seem to be cycling in usage as the POST codes cycle from 21 to 26 and back again...it appears the CPU is running something in the background all the time?
At one point, it seemed that my firewire drive was taking forwever to initialize and report in so I disconnected it, but no change in Post code stat.us
Is it normal for these post codes to be reporting 21 and 26 all the time when before, after a good boot "20" was displayed and stayed that way?
Is the CPU temp truly "too high"? I have only a generic heatsink and fan. Case temp (Antec P160) is 30C and PWM is 38C. If too hot, I'm looking to get a Thermal
Right900, they say it will fit in case OK...
"Everything" appears to be running properly and other than two spontaneous reboots...nothing weird that I can see.
Running WindowsXP, 512 MEG Kinston DDR400, ATI AIW 128 Pro (old I know...), Antec TruePower550W Powersupply, CDROM and CDRW-USB2,
Thanks in advance, been lurking around here for weeks!!
G
G
