- Jun 29, 2006
- 986
- 0
- 0
I'm trying to find my max HTT. I've been adjusting my HT multiplier as I go to keep the 'FSB' at or below 1000MHz.
I started at 220 MHz, and soft reboots didn't work from windows. Around 300 MHz, soft reboots quit working from the BIOS (as in, after I save and exit, I won't boot back up imeediately, I have to powerdown and power back up - I usually go back into the BIOS to make sure my settings took, and then I exit without saving and it will reboot fine).
Is this a problem I should be concerned about and, if so, what can I do to fix it?
Rig's in the sig.
Rig's in the sig.
