An Old Subject / 3pin to 4pin fan headers
Pelltuk
I know that this is an old subject. I have just resurrected an old PC which has got a NEC Bogota MS-7295 MB and is fitted with an AMD 2 processor. Because the fans were making so much noise I decided to replace them all with super quiet ones. The CPU & heatsink combo is a Gelid Siberian Pro and is perfectly adequate for what I require, but comes with a 4 pin connector and my MB has a 3 pin header. No problem I hear you say just leave plug over hanging, the fan will just run at full speed.
When I switched on the PC, the fan ran for about 10 seconds then stopped and the blades were just twitching slightly, after about 10 minutes of no fan activity I decided to check temp of heatsink. It was getting rather hot to the touch so I switched off.
I have got another old cpu fan with a 4 pin connector so tried that with same results, looking at connector wiring it was Black,Red, Blue then Yellow ( cant tell on new fan as all are black) Now I have always been told that the blue is the pulse line for speed control not Yellow, switching these 2 around in the connector now lets fan run at full speed so did the same swap on the black wires.
Any thoughts or comments would be gratefully received as I would rather the fan did not run at full speed all the time.
12,553
many fan controllers can do both analog and PWM, check out BIOS settings to switch to analog. on mine its "Manual" that activates analog
