- Jun 30, 2004
- 16,651
- 2,030
- 126
This shouldn't be an irritation to forum members: If you have no interest in the thread -- avoid it!
Here's the scenario:
You have a midtower case with good airflow. You use a heatpipe cooler for the CPU. Maybe!-- You have the cooler ducted to the rear exhaust. Airflow CFM intake is such that Intake >= Exhaust.
AND -- you have 2x SLI with a pair of "Twin-Frozr" cards: dual-fans with heatpipes poking out of the assembly, as distinguished from the ubiquitous barrel-fan reference design. You do not water-cool the graphics cards.
Here's the challenge: Remove the PCI-cover-plates between/above each graphics cards and verify that you get a reduction of 1C to 3C in temperature for the hottest (upper) card under some consistent stress-test -- either FurMark or Heaven BenchMark, for instance. If there is actually a slight difference, it will still show up in the highest temperatures for both cards.
I THINK I recorded a difference, but at this point, I'm even a bit suspicious of my own imagination.
WHY? Because adding that ventilation, if it really poses some slight difference or improvement, means that a bigger difference or improvement can be possible -- maybe with an extra fan, maybe with only passive cooling "enhancement."
