An Enthusiast Review of CoolClouds' Revolutionary CPU Cooler Prototype
TheHobbyist
24
The reason OCN deleted the thread is because I posted in there about the OP potentially being affiliated with the company making it a sponsored review. I guess the forum managers looked into it and deleted it because no sponsored reviews are allowed there unless specifically mentioned as such and a community based test.
Hello VSG!
That's too bad but no hard feelings. I would have likely drawn the same conclusions in your situation in retrospect.
The forum moderator did just jump in and delete it immediately. However, I have been in contact with both the moderator and the management to clear up the situation. I'm sure it will be resolved one way or another shortly, but it seems their management is very busy atm.
Cheers! :thumbsup:
TheHobbyist
24
Rhett,
This is the problem some of us here and on other forums have with this thread.
Lack of disclosure.
You fail to mention that in June you were/are running the CoolClouds sponsor showcase @ overclock.net - http://www.overclock.net/t/1498226/unable-to-access-coolclouds-sponsor-showcase
And then after posting the exact same review @ overclock.net as you did here, why did your review completely and utterly vanish from that forum.
http://www.overclock.net/t/1503263/an-enthusiast-review-of-coolclouds-revolutionary-cpu-cooler-prototype#post_22604322
Why did they delete the thread, especially since CoolClouds has been listed as a vendor partner there since 12/13.
http://www.overclock.net/t/1452713/welcome-to-coolclouds-new-sponsor/120
Threads get locked all the time, but threads don't get deleted on just a whim.
[H] is the only forum that hasn't completely crapped on your review - yet.
Total honesty of your involvement, your fanboi status, your contribution to the crowdfund, your "team" status, etc. would have made a difference in the way people "looked" at the review.
Or maybe you knew that, I just don't know.
I don't think it would have helped anyone's opinion of the product, it just doesn't cut it as a measurable improvement over what is already available.
You mention that you styled your tests as to fall in line with other testing sites, but what you failed to do, and that they do, is to be upfront about any involvement or history with the product or company.
This cooler will probably end up like CoolClouds first attempt at crowdfunding a subpar/overpriced/premature-to-market cooler
http://hardforum.com/showthread.php?t=1792657
BTW - That "cool_it_man" expounds, espouses and writes similar enough to be related to you.
Hello Micrornd,
I'd like to request that you just refer to me as TheHobbyist, my account name here. I didn't volunteer my real name and I ask that you respect my privacy.
I'm just an ordinary guy. It took me a lot of my free time to test the coolers and write up the review. I was primarily focused on getting the test done and putting the information together. The test and the review was for overclock.net and the community there, I just chose to share it here and at the 2 other sites as I read them frequently at my leisure. Whatever mystery or doubt that is surrounding this review wasn't something I saw coming. For your benefit and the benefit of others, I will put together a more lengthy disclosure as I get free time from my work and my family. In my introduction, I touched on how this all came about and went down. In writing this, I focused more on the coolers and the data than the backstory.
From reading your messages to me, you could be related to a few people I have met over the years as well. I will have to go back and read what cool_it_man has posted, he sounds pretty awesome. :thumbsup:
You had a lot of criticism of my testing methods. I started putting together a second test and requested feedback. Would you like to contribute any?
<quote>
I am working on "Test Bed #2" and it would be great to take community feedback about how you would like to see coolers tested and what tests you would like to see.
So far the questions I will try to answer with "Test Bed #2" and subsequent testing are as follows:
How great of an effect does side panel on vs side panel off effect the thermal performance of each cooler?
How do the CoolClouds prototype and the Corsair H80i perform with no fans (cooler fans or case fans) but with the pump running
How do the CoolClouds prototype and the Corsair H80i perform with fans, but no pump
How do the different cooler form factors (I.E. AIO and motherboard mounted) affect the temperature of other components in the system? (i.e. CPU temp, case temp, vrm temp, cooler intake temp, etc)
How do the 3 coolers perform using cooler intake temperature instead of room ambient
How are temperatures affected by different AIO radiator placements (i.e. placed in rear exhaust as an exhaust, placed in rear exhaust as intake, placed in front intake as intake, etc)
What do you think?
</quote>
Micrornd
1,294
182
Hello Micrornd,
Sorry, I thought that since you used it on the CoolClouds fund raising
page it was out there.
I won't use it again.
What do you think?
Unlike some over at [H], I think testing should be done in a closed case to approximate real world usage.
The radiator on an AIO has several places it can be positioned (front, back, top, bottom, side) and airflow as an intake or exhaust through it.
This integrated radiator/HS has a single place it can go in the same case, same MB.
Airflow through it can be changed, but it's location can't.
Very few people run their setups permanently on a test bench where it is easy to adjust things to get optimal airflow to a HS to cool it's best possible and produce it's best numbers.
That's akin to cooling a cpu with LN, sure it produces really good numbers, but it's not how things really work in 99.99% of usage.
That same miserable 2 core would have it's a** handed to it by a slower 4 core in the real world doing real work with regular cooling.
Put a quality fan cooled HS in a PC, run the tests, replace it with the CoolClouds, run the same tests, that's a much truer comparison of how well it really works and how 99% of users will actually use it.
Do the same thing with an AIO and the Noctua. That's how the coolers will be used, not sitting of a bench with fans blowing whatever way allows it to produce the lowest numbers.
Remember CC is marketing this thing as a drop-in replacement that will cool better than what is currently in use, not as something that cools better on a test bench.
Yes, the case factors in to the equation, but people put these things in cases.
And they are not going just run them for 15-30 minutes, either.
How long is your PC on a day?
The uptime on mine is currently is 283 hrs.
Cooler air intake temp? Really? Who cares?
Of course ,if you give any cooler, cooler air to start with, it will perform better.
Simple physics and yes, some will perform better than others.
BUT, how does that relate to everyday usage?
It just doesn't, since the CC cooler is stuck on top of the cpu, it is at a disadvantage to a AIO, but that's how it will work in real usage, and the way it will work with the Noctua also.
Only people that don't use there PCs care about unrealistic bench tests.
99% of users aren't benchmark queens, they just want their stuff to work in their PC.
Any tests should reflect real world usage.
Think about it, how much micro-stutter does AMD see in running benchmarks, compared to playing games.
So if they fix the drivers to eliminate micro-stutter in benchmarks, what happens in games no longer matters right?
No, but that's an example of bench testing compared to real world usage.
I see no real reason to test it with the pump disabled, if that happened in real usage the cpu would throttle or shut down (or in some cases the MB would shut down).
I am glad you mentioned VRM temps as it's the cooler's job to deflect some air downward to cool the vrm's, at least per Intel's socket/HS thermal design specs.
AIOs forget to mention this need, as do some fan based coolers also.
The bigger problem is still that this is a prototype, meaning the production unit may be worlds apart, better or worse, especially if they (CC) follows through with their proposed multi-vendor production vision.
Prototypes are for proof of concept, not real evaluation against other products.
Compromises will have to be made for production runs.
How that affects the CC cooler.................
With 10 days left and less than $300 out of $100K in fundraising, it's probably a moot point
Spanners
325
Recently, I had a very unique and exciting opportunity present itself.
I would like to thank the fine folks at CoolClouds for the opportunity to work hands-on with their first prototype and for their open-door policy regarding any questions or comments that I had throughout the experience.
This seems a bit disingenuous to me, did this "opportunity" present itself before or after you wrote your glowing endorsement on their Indiegogo page and bought the T-shirt?(Seems the campaign started on Jun 16) In the same vein it's hardly surprising that the company was happy to answer your questions when you are essentially writing their marketing material.
I personally enjoyed the part where you were skeptical of the 16mm radiator but then it won you over with it's superior performance. Credible.
You also seem to have an unholy enthusiasm for referring to yourself as an enthusiast.
Sorry if this makes me a "hater" this is just how I see it.
Ramses
2,871
4
Wow I thought I was bitter and distrustful and cynical.
This thread has not only been about an interesting, and more importantly, different, cooler, but it's improved my self image. :)
Madpacket
2,068
326
No offense OP but this has snake oil written all over it. Your enthusiasm is actually derailing your message and revealing your true colour, that's why you're getting called out. Your writing style looks like it came from some crappy "Internet marketing 101" course similar to the fake reviews you see at Amazon. In other words GTFO, you're not fooling anyone.
taq8ojh
1,296
Haha, that's probably the best reaction to this guy I've seen across several forums :D
doyll49
112
Testing in a case is only "real world" for the system in the case as tested .. that is the one and only "real world" that can accurately re-create the test environmental conditions and hopefully consistently same results. None of our "real world" systems are the same as tester's, especially if overclocked because each chip performs differently.
At the very least we need to know the cooler / radiator intake air temperature .. and that temperature cannot vary more then 2-3c. If it does, the delta temps will not be consistant .. A CPU reading of 70c with intake is 25c translates toa delta of 45c, same as CPU at 75c and intake of 30c gives a delta of 45c. But the actual cooling is not the same 45c cooling that delta temp gives us. Same applies to barometric pressure and humidity when testing. This is why when doing scientific testing there is a standard base test ran for each testing sequence.
Testing on an open test system is best because it is easier to keep intake air temp the same thus giving us real cooler results instead of system results, but we still need to monitor and record the cooler intake air temperature.
Using room ambient as cooler intake temperature when testing in a case is like using the temperature outside your house to determine what your room temperature is. :D
It is not hard to monitor cooler intake, nor is it expensive.
Now, as for TheHobbiest's CoolClouds thread, it's an "Infomercial" not a review or accurate and scientific test. No varying loads, no different fan speeds, .. and most of all no cooler intake temperature record. ;)
It seems to be an attempt to bridge the gap between air and H20 coolers, .. more specifically to bridge the gap between air and CLC .. to make a CLC with no hoses. I just don't see it as a viable alternative.
The only new concept cooler I've seen that looks interesting is the Captherm Systems MP1120. But will it be able to top the cooling of others and be marketed at a competitive price remains to be seen.
No, that is not his hand you see in the base sight-glass. It's the sintered nano coating to create additional surface area on the liquid side of base.
If you want more infor on the MP1120, ask and I'll start a thead with what little I know about it.
BonzaiDuck
15,877
1,548
Just eavesdropping on all this.
First, I want to correct views about the "massive" NH-D14 and D15. And -- I don't work for Noctua.
The concern about stress to the motherboard isn't only about weight -- it's about torque. I good part of the bare-bones weight of the d14/d15 is the base, which means little or no torque. I suppose the rest of it would be to take the height of the cooler and multiply the midpoint by the weight of the fins and pipes alone. Whatever it is, it's not a lot.
Instead, the fans contribute roughly 7 to 8 oz per fan -- maybe a little more because the Noctua fans tend to be a bit heavier. the 120 or 140mm Noctua fans seem to be in excess of 6 oz. With two fans, that's 3/4 lb. There's your torque. But there's quite a few ways to take the weight off the cooler even if you want the push and pull fans.
This other thing -- CoolCloud -- seems to be mostly copper -- so we're looking at something else there. Add the fan, it's more weight, and more torque. On the up side, it supposedly takes up less space-in-da-case.
On the down-side, if we can trust Hobbyist's tests, there's hardly any difference in the effectiveness of the cooler. What we'd LIKE to see is ANY heatpipe cooler that could SIGNIFICANTLY outperform -- say -- an H110 AiO. I think there's a consensus that heatpipe-air-coolers can't get much better.
So - thanks for the review, but no stunning breakthrough with that . . .
