Originally posted by: ragazzo
That's because your sentence is incomplete.
"At any rate using this process in another system that does allow..."
Allow what?
"At any rate, using this process in another system that does allow it, then it is an excellent idea".
Originally posted by: Perry404
Are you sure? I used this sentance in another thread this morning:
"At any rate using this process in another system that does allow it is an excellent idea".
It occured to me that if you replaced the "it is" with "it's",
"At any rate using this process in another system that does allow it's an excellent idea".
...it just doesn't sound correct.
Agreed. The subject of your sentence is "using this process in another system that does allow it"Originally posted by: jagec
It's correct, but sometimes one way sounds better than the other.
No, it would not be, because "it" is PART of the subject.Originally posted by: Perry404
So then would it be correct to say that "it is" can always replace "it's" and vise versa?
That's actually wrong, no commas are needed. It's just like saying "At any rate, using is an excellent idea," only with extra words after "using" to further clarify the subject.Originally posted by: Mathlete
No
You can't use it's because you need a comma in there. What are you going to use it',s.
Correct: At any rate, using this process in another system that does allow it, is an excellent idea
