http://www.rootminus1.com/howard/pics/fullsizeatxchassis.gif
http://www.rootminus1.com/howard/pics/hd%20cage%20top%20down%20view.gif
The thing on the bottom left is obviously the HD cage, but the 2nd pic will tell you all of it. The HDs are suspended by rubber cords attached to the cage and the eye-hook screws. The front "baffle" with the foam should be able to pop off with everything installed and the cage itself can be slid out the front (cables might prevent this).
Comments?
EDIT: Front-bottom dust filter is 1" thick like standard furnace filters. Also, SA is the abbrev. for "sound absorbing". All the foam is 1" thick except the stuff inside the front baffle.
Plan 2, EATX-enabled
Comments?
