- Dec 14, 2000
- 680
- 0
- 76
Yes these machines are still going strong, if not a bit long in the tooth.
I want to replace my 3.5" HD in my 1200 with a larger model, but I'm not sure if the standard PSU will handle the larger drives current draw. The standard PSU specs are:
Total 25W
+12V 500mA = 6W
+5 3A = 15W
-12V 100mA = 1.2W
Currently I have an IBM 330MB 3.5" HD in my 1200 with the following power requirements:
Current HD
RPM=3800
I slaped this baby in 10 years ago and everything is still going strong.
Recently I purchased a 2GB seagate HD to replace my IBM. These 3.5" drives are ideal for 1200's because they're so small. Compare these physical specs:
IBM 3.5" & every other brand: Ht 25.4mm, Wd 101.6mm, L 146mm
Seagate 3.5": Ht 19mm, Wd 102.1mm, L 127mm
I had quite a bit of trouble with the height of the IBM, but the seagate slips in the 1200 like it was made to fit. The only thing left to worry about is the power requirements. Luckily I also have an old PC with a 1.28GB seagate HD, so I can basically place either the 2Gb or the 1Gb seagate hard drive in my 1200.
The reason I'm sticking to 3.5" drives is because I've already got all the leads and done the required mod to make them fit.
Here's the specs for the 1.28GB:
Seagate 1.28
RPM = 5200
and the 2.11GB:
Seagate 2.11
RPM= 5200
Questions:
Can anyone tell me which one I should choose?
Will the current draw be too high for the standard PSU?
Will the drive spinup fast enough for the 1200 to boot on second attempt (like my IBM does at the moment)?
Thanks for anyone?s help, much appreciated!
Total 25W
+12V 500mA = 6W
+5 3A = 15W
-12V 100mA = 1.2W
Current HD
RPM=3800
Seagate 1.28
RPM = 5200
and the 2.11GB:
Seagate 2.11
RPM= 5200
Questions:
