An actual power supply measurement
KF
I measured the input to a computer at the power cord with an ammeter. It came out 0.65 amps at idle/normal. That's 78 watts input total. 0.97 amps under prime95 (blend) load. That's 117 watts input total.
The mobo is an MSI K8N Neo2 Platinum, with a Winchester core Athlon 64, at 1.42 Volts, OCed to 2250 MHz.
Cool and Quiet is disabled. The HD is spinning, not powered down, and there is just a CPU fan and the PS fan, no case fan running, because the case is currently open while I'm in testing/experimental mode.
On a second computer, it came out somwhat differently. It has a DFI NFII Lanparty mobo, with a Tbred Athlon XP at 1.58 V, OCed to 1870 MHz. It comes out 0.93 to 0.98 at idle. It wanders a bit depending on what is running. That's about 120 watts total. If I fire up prime 95, it goes to 1.16 amps, which is 139 watts.
I tried burning a CD to see what the power-delta is. That would give an estimate of the extra power used to burn. With a blank in the drive, and Roxio Easy CD Creator running, it starts out at 1.08 A and wanders down to 1.03 before the burn starts. I think the wandeing is the CD drive spinning up to identify the CD and spinning down to a lower idle rpm. While burning it goes to 1.14 at burn speed of around 30x fot that blank. So the difference is 0.06 to 0.11. So burning a CD draws about 13 watts extra.
Just putting a CD in the drive makes the amps go to 1.20 for a second, then it backs down to 1.04 or so. When you play a CD it mostly near 1.04, while the green light goes on about once every 1-2 seconds. I believe the OS reads breifly at some multiple of the speed (10x?) and buffers ahead enough to play continuously.
Just to do the math, if all the power were to the 12 volt rail (which it isn't) , 120 watts would be 10 amps. Since powers supplies are estimated at 80% efficient, the PS would be putting out 8 amps. In other word the PS couldn't be supplying over about 8 amps on the 12V rail in actual use.
Yes but those systems look... Weak.
Try running 3DMark05 maxed out.
Try out a:
Dual Opteron Setup with Two Video Cards
Dual Core Setup with Two Video Cards
High speed single core with two video cards
A Dually Server with 10+ HDs running HDTach and PCMark
