- Jun 1, 2000
- 1,499
- 2
- 81
okay here's what I did...
Quick Flash Instructions For AMI Motherboards:
(FLASH UTILILTY NOT REQUIRED)
· Unzip file, copy the "ROM" file to a diskette in "A" drive.
(Diskette does not have to be bootable).
· Make sure your using the on board floppy controller.
· With system powered off and diskette with "ROM" file in "A" drive.
· Hold down on the "CTRL & HOME" keys and then power on system.
· There will be no video and notice floppy drive being accessed.
· You should hear 1 beep let go of keys.
· Then you will hear 2 beeps and then 3 beeps.
· System should reset and notice new BIOS release date at top of screen.
· Enter BIOS SETUP run the OPTIMAL SETINGS OPTION.
· Change BIOS SETTINGS for your configuration.
but the only problem is that is just keeps beeping twice never hits the third beep sequence any clues??
been beeping for about a half hour
