AMD64 3500+ With a Abit KV8T800 Pro, Need Help
Pittfan
I was wondering if anyone has any set ups or a guide with the AV8 included as a Chipset in Tut ? I'm trying to OC this chip past 2.4 ghz any suggestions ?
o1die
4,785
The via chipset boards don't overclock well. 2.4 stable may be all it's good for.
Pittfan
OK i have this set up , sorry i shouldve posted it :
AMD64 3500+ Stock 2ghz , I'm @ 2.4 ghz with Core Volt @ 1.55 (Winchester)
Abit AV8 K8T800 Pro Mobo
Corsair XMS TwinX 2X1GB DDR 400mhz
HIS HD 4670 1GB DDR3 AGP8X
P.S. If I can't get any higher then 2.4 ghz that's ok . I ordered a Phenom II 550 for a new build , i just wanted to learn to OC before I build new System, Thanks For Replys
SonicICE , Yeah that mobo
spdfreak
979
I have a soltek MB with the via chipset and a 3800x2 and it won't get over 2.4 either. It is the chipset... But, if you want to run it at stock or just slightly OCed, it is a very stable chipset.
