AMD Wraith - AMD's new box cooler to be shipped with Zen - Temperature tests
Burpo
4,223
473
Not as loud and annoying as the guy in that video tho..
MrTeal
3,919
2,708
my fx didn't come with that D3 cooler :colbert:
59*C is not 13% warmer than 52*C. :colbert:
You're right of course, you need to use scientific units. 52C is 125.6F, while 59C is 138.2F, so it's really only 10% warmer.
:cool:
Erenhardt
3,251
105
101
:cool:
*flip table*
52'C is 325.15' K
59'K is 332.15' K
332.15/325.15*100%=2,75%
It is 2,75% warmer using scientific units.
railven
6,604
561
Really wish they'd use better angles or at least flat out show that it doesn't obstruct the RAM slots if you were to use a kit with high raised fins.
Even that Corsair set, which isn't very tall, almost looks like it wouldn't fit, but of course the camera never goes far enough to show the clearance.
EDIT:
This image shows it will probably be fine with higher finned memory, but that's super tight for my liking.
http://images.bit-tech.net/content_...8370-cooler-review/amd-wraith-9-1280x1024.jpg
mikeymikec
21,428
16,635
It seems to me that they've opted to use a cooler that can do the same job as its predecessor was meant to do (ie. the same or very similar demands), just more quietly (ie. increase the size of the heatsink and use a more appropriate fan). While that's better than a kick in the teeth, Intel's stock HSFs have been getting steadily smaller and quieter for some time.
AtenRa
14,003
3,362
If they will use the Wraith on the ZEN CPUs doesnt mean they will release 125W TDP SKUs.
A10-7870K comes with the D3 cooler and its only a 95W TDP CPU.
LTC8K6
28,520
1,576
It's meant to go up to 8 cores, so 125W isn't really surprising.
No, not surprising, but it would factor into the mix.
Zen might be fast enough to compete, but then a higher TDP could knock it back...
