Question AMD/Sapphire 5700 XT Triple Monitor Issues
RyanGreener
550
Okay, I'm just going to copy and paste what I asked on Reddit regarding triple monitors in Asseto Corsa/Sim Racing.
"Hello everyone. I'm not sure if it's this specific game or not, but I cannot for the life of me get triple monitors to work properly. I have 3 identical monitors with 3 identical cables running at 1920x1080 each. Drivers have been installed, uninstalled and all that other basic troubleshooting and still doesn't work. I've tried Eyefinity custom resolutions and it won't let me go 5760x1080 (only 5760x931) and they don't even line up properly across the screens with the 931 height. I've tried modifying the video ini cfg file to 5760x1080 and AC ignores it and sets it to 5760x931. This is also a fresh Windows 10 install (I just built this computer for this kind of thing). Is there a way to set up triples WITHOUT EyeFinity? If it helps, I'm running an I7-3770k + AMD Sapphire 5700 XT"
I've done a LOT of internet searching everywhere and I'm really stuck at this point.
Shmee
8,313
3,177
Not sure if this is relevant, but what cables are you using? You may need DP or HDMI for infinity, though I am not sure. Also, just so we know, is this card the reference, the pulse or the Nitro+?
Stuka87
6,240
2,559
So, did you upgrade to the 5700 XT from the 1660Ti you previously had this issue with?
RyanGreener
550
I believe it is the Sapphire pulse model. Also, the 1660ti never ran on triples.
My cables are DP to HDMI and the monitors accept HDMI.
Zstream
3,395
277
RyanGreener
550
Okay so I tried to check things out again. I am assuming I have to turn on EyeFinity for this? The Triple Screen app does not show if I do not....and I'm trying to avoid eyefinity because I can't get the correct resolution.
