Question AMD Phoenix/Zen 4 APU Speculation and Discussion
Page 15 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
TESKATLIPOKA
2,696
3,260
Personally I hope all designs using dGPUs will build on Dragon, with Phoenix mostly left to its iGPU. I also expect both to be announced at CES, though I'd be surprised Phoenix to see any relevant availability in the market before Dragon.
I don't think Phoenix will be limited to only IGP. The reason being that Dragon Ridge will be most likely only 12C and 16C and for gaming even 6-8 cores are enough and that is Phoenix. 12CU RdNA3 will be pretty strong, but nowhere near comparable to a dGPU solution. Even a cutdown 24-28CU N33 should be at least 2x faster.
8C16T Phoenix + N33 will be a pretty decent gaming solution.
moinmoin
5,248
8,463
Phoenix won't be "limited" to iGPU, but I sure hope the selection of products not including a dGPU will increase significantly. Also I don't think Dragon Range will be limited to above 8 cores, Dragon Range + dGPU are a perfect fit since in that configuration TDP and battery life are usually not considered limiting factors anyway.
Reactions: Tlh97 and Kaluan
LightningZ71
2,696
3,395
If current speculation holds true, Drago Range being based on Raphael will give a larger L3, which is important for many games. That leads me to believe that there may be at least 8 core Dragon Range CPUs as they would still have a notable performance benefit over a half-L3 phoenix part. As for when they will actually hit the market? Well, going by AMD's recent track record, they will introduce the two products at CES, then, about 6 months later, a handful of OEM designs for the major business markets will start to appear as well as a small number of super-high end parts from one or two laptop makers that will be in extremely limited volume at astronomical prices. Then, about 9 months later, you'll start to see mainstream notebook parts that were announced in the spring and summer to become available in the normal channels. It'll be about a year from they are announced for products with reasonable pricing for their market segments to become widely available on the market.
As for RDNA3 on Phoenix, please note that, from what we're seeing from driver commits on linux, RDNA3 as it exists on Phoenix will be notably different from the dGPU version, and seems to be more of RDNA2 with expanded and restructured caches and a couple of functional unit tweaks. This makes some sense as it will exist in a highly bandwidth constrained environment, won't have sufficient transistor budget to make some features worth implementing, and will likely be more focused on providing better performance for FSR/XeSS so that it can provide good performance at 1080p/1440p.
scineram
376
295
It won't be enough in gaming or competitive at all if it still has pathetic 16MB L3.
TESKATLIPOKA
2,696
3,260
It's true that Rembradt without dGPU was mostly the lower TDP one, but Rembrandt laptops weren't that many to begin with. Hopefully It will be much better in this gen.
Is It better to use Phoenix or Dragon Ridge with one missing CCD for an 8C16T gaming laptop? Probably 8C16T Dragon Ridge could be cheaper to produce, but power draw won't be much better than Raptor from 45-88W based on that table from ComputerBase, but that needs to be verified, If It applies or not to the mobile chips.
I though Phoenix IGP is(will be) the same as N33.
I think they will finally move to 32 MB. At least I hope so. :)
moinmoin
5,248
8,463
@TESKATLIPOKA The name is Dragon Range. ;)
I'd think Phoenix Point will use the usual denser mobile Zen cores. I personally expect it to be the same as the cores in Zen 4c Bergamo, which is already confirmed to have 16MB L3$.
I'd expect Dragon Range to have a lower idle/base power draw than Raphael, but beyond that and binning the table from ComputerBase should apply.
Regarding the scarcity of Rembrandt laptops, that's quite odd thinking about it. I argued before that like in previous years corporate demand hooked all supply, but then AMD reported mobile units and shares crashing last quarter. So Rembrandt laptops apparently weren't being made in the same quantity as previous gens at all (and AMD officially didn't see that coming)? In that case one can only hope companies are more daring with upcoming laptops using Dragon Range and Phoenix Point.
moinmoin
5,248
8,463
Wtf would they use 4c cores when they want these to be clocked above 5 gigahurtz?
Phoenix Point won't clock that high, mobile first chips never clock as high as desktop chips. That's what Dragon Range will be for.
LightningZ71
2,696
3,395
The current 6000 series mobile chips boost to 5+ghz on N6. I don't see them backtracking on that in the slightest. I do see them sharing the same CCX layout between bergamo and phoenix. Its a hallmark ofAMD to reuse as much IP as possible wherever it makes sense. This would be no exception. For lower mid to midrange mobile, 16MB of L3 is both plenty and competitive. For those that want to wring every last FPS that they can from their CPU, there is Dragon Range. For those that just need their laptop to turn on, sip power, and put a picture on the screen while they surf the internet and do office type tasks on web-apps, mendocino covers that market well enough.
Reactions: Tlh97 and Kryohi
Bigos
234
592
No way AMD will use Zen4c, which sacrifices single thread performance for higher density, in a client product. At least not without a non-c core in the same package (and I doubt we will see hybrid cores from AMD anytime soon).
Bigos
234
592
All of AMDs mobile APUs so far did just that. I don't recall people complaining about the frequency difference before, and this time there's Dragon Range as alternate choice.
Not really. For example Rembrandt boosts up to 5GHz, which I believe won't be possible with Zen4c due to the use of high density libraries.
Reactions: Tlh97 and scineram
uzzi38
2,747
6,657
Zen 4c vs Zen 4 is a bit of a complicated affair. It has it's own v/f characteristics - it doesn't behave like Zen 4 always does. Not going to give too much context but the efficiency cross over point is a bit too low.
As for Dragon Range, if AMD can get Genoa idling around 15W, I'm gonna freak if they can't get Dragon Range idling lower than Raphael does.
Kaluan
517
1,100
Do customers for DTR laptops even care about idle that much tho?
What they care about is speed and laptops not burning a whole through their desk while they complete that 3h render in Cinema4D.
With the new media engines in RDNA3, what are the odds we see AMD claim some wild 30 hour video playback battery time for Phoenix designs? 😅
Reactions: Tlh97 and moinmoin
