- Dec 29, 2010
- 3,034
- 1
- 81
Hi all,
I'm wondering if it's worthwhile to undo an overclock when I'm not gaming, in order to save power?
I have an AMD Phenom II X2 555 BE, and I'm able to run all 4 cores at around 3800-3900 MHz if I want to overclock for gaming by increasing the multiplier and the base frequency (for cpu bound stuff like starcraft II etc. where it makes a difference).
But since I don't game every day, i feel like it's a waste of power to run all 4 cores at such an overclock, even though i turn on all power savers like cool'n'quiet etc., though I think sometimes those are not going to help if you exceed a certain Mhz in your overclock (verify this? is it exceeding a certain multiplier, and/or exceeding a certain frequency)?
So now I'm just running my PhII 555 chip at stock, using 2 cores at 3200 MHz, and putting up with slowdowns in starcraft II when lots of units are on the screen, moreso than if I'd kept the overclock.
But is there a way to overclock such that I can retain all the power saving features, so that my computer would be able to throttle when i'm browsing, but then have more performance available when I fire up SC2 every few days?
Am I overestimating the overclocked power consumption vs. stock power consumption, by not taking into account that the chip will throttle itself during normal browsing even if it is overclocked with all 4 cores active @ 3850 mhz instead of just 2 cores at stock 3200 mhz? Are we talking pennies a month for this type of overclock (with power saving enabled) compared to stock (with power saving enabled), or would it be a worthwhile savings to keep the chip at stock all the time?
The video card is not a factor as I'm not going to overclock the video card, just the CPU to help out Starcraft II when i play it. I'm not GPU bound, as it's a 5870 and I don't use antialiasing.
