AMD hot fix just boosted my sandy in cinebench
formulav8
7,004
522
Hopefully Anand does a nice review of the patch, as he did with the TLB patch and eventual stepping fix on Phenom.
Well don't hold your breath for him to do much of anything AMD. :whiste:
But hopefully he will. :)
Phynaz
10,140
819
What do you mean "official" there are people on this forum which produce more accurate and authentic results than any hardware site, AT included.
What I mean by official is MS stating this does something for Intel chips.
A few random posters on the net doesn't mean it does anything. As far as I'm aware, according to MS this patch only works on BD chips. Which would indicate they ID the CPU.
Diceman2037
54
This is a backport of the windows 8 scheduler, changes that affect all processors were likely left in place.
tweakboy
9,517
www.hammiestudios.com
What about me? Can use this hotfix,
BTW I can't find the hot fix onlien anywhere, google all sites micrsofot seems to have removed the hotfix.
If this hotfix can give me 3 more fps a second Ill do it.
Can I have a working link for this, or you guys things its waste of time for me.
thx gb gl
grkM3
1,407
here ya go guys,this is the original file that MS put up and then took down with an updated 2 file install.
use at your own risk and this is for windows 7 64bit
grkM3
1,407
Wow thanks big time, grkM3 .. thank you my brother.. Oh wait since they took it off ,,,,, its a really big risk uh ? thx gl
thats the file I have been running for a little over a months now.
before you install run cinebench and post before and after gains.
edit I saw the gains on my 2600k,I dont know what it will do with other intel chips.I thinks its just a better way for the OS to handle more threads like others have said and it will install no problem without an amd cpu installed
Kenmitch
8,505
2,249
I tried this above patch for my somewhat unscientific testing.
It does seem to have some effect on my 2700k. My board in sig is in the rma process with Asus. I'm currently using a ASRock P67 Ext4 Gen3 I picked up as a temp board with a 2500k for future testing....Microcenter bundle :)
I'm still trying to dial in my 2700k at 4.8ghz as this uEFI is primitive compared to the Asus implementation....It's doable but takes some more tweaking to get there. Taking some effort as I'm testing with Intel Burn Test using the (ALL) threads setting which HT doesn't like I hear.
Initial testing shows the GFlop output is alot more consistent. The GFlop output did somewhat scale a little better the more memory I used. The system seems more responsive when IBT is running and I try to surf the web or view screenshots of GFlop output for referance.
The downside is I need to tweak this overclock a little more and got a bsod on the 10th run of 6000mb of IBT. I was using the default of 1024,2048,4096, and picked 6000mb custom to keep the results more consistent. Didn't get the after screenshot :(
I'm gonna go for another round without tweaking any settings and start with 6000mb as it was most likely a random bsod due to HT and using ALL cores instead of changing to 4 threads like most suggest using IBT with HT chips.
Diceman2037
54
you can use the 1st of the 2 file fix, it does the same thing except it also includes a newer version of powercfg
grkM3
1,407
ok guys I just did a test on a clean windows 7 64 with sp1 install.
system running at 4.8ghz with a 2600k and with 8gb ram at 2133 9-10-10-2t
ran cinbench 3 times with out the patch
first run
9.27
second run
9.32
third run
9.38
installed hotfix that I posted above and changed nothing else in the setting
first pass
9.47
second pass
9.47
third pass
9.47
this hotfix is awesome and windows spreads the load on the cores a lot better and the results are real.
the new hotfix windows put out wont let you install with an intel chip but the one I posted above works and it came right from microsoft.
and to anyone that benches with cinebench going from 9.38 to 9.47 would need to overclock the cpu about 150-200mhz to get that increase in cinebench
red454
205
www.cardomain.com
I saw a similar improvement with that patch (Windows6.1-KB2592546-x64).
Not a huge gain, but I'll take it. And thanks grkM3 for posting it...
Diceman2037
54
why would firefox 12 include the fixes of firefox 11?
the file versions inside (where it matters) are within 3 revisions of the second version of the scheduler hotfix.
the first version of the scheduler patch has an older version string then the force ASLR hotfix
do the math.
Lonbjerg
4,419
first run
9.27
second run
9.32
third run
9.38
first pass
9.47
second pass
9.47
third pass
9.47
So an "improvement" from ~9.3ish to 9.47 is "awesome"?
lulz
