AMD hexa-core Thuban CPU clock speed leaked
veri745
1,163
4
Check the HT clock speed (240MHz), it is overclocked by 20%. That means its stock is ~2.8GHz.
Aha. Hopefully they all overclock as well or better. I wonder what kind of juice it's pulling at current PhII 955/965 speeds.
cbn
12,968
221
Hmmm.....Six cores @ 2.8 vs four cores @ 3.6 and both having 6MB L3 cache.
I wonder how much better Phenom II x6 will scale? Do encoding programs and Photoshop need less L3 cache per core?
Soleron
337
The clockspeeds are actually good news. Not included in the leak was the 1075T, which we can now assume to be 3.0GHz. There's also going to be a model above that the following quarter, presumably 3.2GHz.
Add that to the possibility of a Turbo-like feature (unconfirmed) or that it includes Magny-Cours' IPC boost (which JF did confirm, but we don't know whether that was put in Thuban too) and in Q3 we could have a six-core with single-thread performance greater than the 965 today.
Also in the link below, the quad-core 960T is listed above the 965. If I'm not reading too much into it, the 960T is 3.3GHz; it would need an IPC boost to be better than the 965. So maybe the IPC boost is plausible?
http://news.ati-forum.de/index.php/news/35-amd-prozessoren/1127-weiterer-phenom-ii-x6-in-q3-2010
LoneNinja
825
I might be mistaken, but I remember reading some where that the stock northbridge speed on Thuban and that new X4, will be 2.4Ghz instead of 2.0Ghz. If that's true, it would mean slightly higher IPC.
Soleron
337
The original source for this listed the system bus as 4000MHz, i.e. 2.0GHz HT.
More important than HT speed is NB speed (because that determines L3 speed), and Istanbul decoupled the two so we still don't know that.
But when JF said there would be a per-clock boost on MC I think he meant over and above the increased HT speed. So if it was to be on Thuban it would be more than just increased HT/NB speed.
batuchka
93
The 95W TDP Thubans would be awesome cos some on budget/cheap AM2+/AM3 mobos could just drop em in for cheap hexacore computing if they needed that much CPU power
jvroig
2,394
Yes, we had a thread about 20 days ago about that. I'll see if I can dig it up.
EDIT: Here it is.
konakona
6,285
That's kinda odd. In practice, it has been shown repeatedly raising HT had no performance gains as opposed to CPU-NB. Is it really supposed to give higher IPC? I thought the take away lesson was Ph II had plenty bandwidth to spare in HT running at 2ghz. Maybe not quite the same with 6 cores?
Soleron
337
Wikipedia's not a source. I could make up some HT speeds and post them as well.
The stepping listed as 'C4' gives it away. The base design would probably be Istanbul (D0) or Lisbon (D1) since they would already have a die with 6 cores and starting from 4 cores again would be a waste. So Dx or Ex would be more likely.
grimpr
1,095
7
Phenom x6 1090T Black Edition
* 6 core
* 3.200 MHz
* 3.600 MHz "Turbo"
* 6x512kb L2 Cache
* 6MB L3 Cache
* Unlocked multipliers
* DDR2 and DDR3 support
* 45nm SOI
* 125W TDP
* ca. EUR 290
Phenom x6 1055T
* 6 core
* 2.800 MHz
* 3.300 MHz "Turbo"
* 6x512kb L2 Cache
* 6MB L3 Cache
* 45nm SOI
* 125W TDP
* ca. 200 Euro
Dark4ng3l
5,061
* 6 core
* 3.200 MHz
* 3.600 MHz "Turbo"
* 6x512kb L2 Cache
* 6MB L3 Cache
* 45nm SOI
* 125W TDP
* ca. EUR 290
Phenom x6 1055T
* 6 core
* 2.800 MHz
* 3.300 MHz "Turbo"
* 6x512kb L2 Cache
* 6MB L3 Cache
* 45nm SOI
* 125W TDP
* ca. 200 Euro
Come on man you need some kind of source you can't just post things like that with absolutely no credibility.
jacques_derrida
Also listed here.
Pretty sure there is not going to be a 9MB cache part (else the server cpu's would have it by now). So I have to consider this inaccurate/speculation.
Again 9MB cache (if Ön Bellek, means cache). Anyway, seems like the retail price will be around $300+.
aigomorla
21,131
3,667
oh nice.. i wonder how much the six core black edition will cost.
if AMD could keep that price below 500, it might even give gulftown a good chase.
Price it over 500, and it will be in the same territory as the i7 970 gulftown, and that would not be too smart.
Plimogz
678
That link says
AMD Phenom II X6 1090T Black Edition
AM3 3,2/3,6GHz Turbo Core 9MB cache,125W
Keep in mind that PhenomII X4 has 8MB total cache; so a 6 core part with the same (6MB) L3 would in fact have 9MB inscribed on the box.
frostedflakes
7,925
That link says
9MB is referring to total L2 and L3 (6MB + 6x512kB).
Looks pretty interesting. I was expecting the Phenom II X6 to be pretty underwhelming, but if they're priced right I think they'll appeal to a lot of enthusiasts. DDR2 compatibility is nice as well for people who want to drop one into an older AM2 or AM2+ board. I thought I read at one point in time that these were going to be DDR3 only.
Gillbot
28,830
17
imho, if they come out with DDR2 support still on the hex's that will give AMD a fighting chance at those later adopters who want a more budget minded upgrade.
lopri
13,329
709
I think at least one model (1055?) should be below $300 to have a chance to fight i7. It would be awesome if it's backward compatible with AM2+ platform as well. At least for those who actually use all the cores.
VirtualLarry
56,587
10,227
That 1090T BE looks SWEET! I think I'll get one. 3.2GHz stock, with 3.6Ghz Turbo (that's pretty impressive for AMD), and SIX cores. SICK!!!
Markfw
May 16, 2002
27,408
16,257
If I can get a 2.8 ghz hex core that fits AM3 for less than $200 , I will trash my failed 550 BE OC, and get it, just to play with !
Gillbot
28,830
17
I'm thinking AMD is going after the "I want more cores/more cores = more better" crowd. Plus, if they keep socket and "older parts" compatibility, this will give Intel a serious run. People will buy them just because, whether they perform better or not. I mean, if it has more cores, it HAS to be better right?
grimpr
1,095
7
Would you prefer the Intel i5 670 at $279.99 with some 32nm moist cream instead? Real cores for me please.
