AMD Freesync Monitors & Reviews Thread
Spanners
325
TESTS AND FACTUAL ANALISYS
http://www.blurbusters.com/gsync/preview2/
"subjective analisys" (the title of the page itself
The panel's 75Hz rate and decent response time meant there was no visible ghosting either. If you're viewing content with a 16:9 or 16:10 aspect ratio, however, you'll end up with large, unused portions of the screen, like you see in the 4K Avengers clip above.
We also did quite a bit of gaming on the LG 34UM67, both with and without FreeSync enabled. We played some older titles like Left 4 Dead 2 (which can run at very high frame rates), and some newer titles like Crysis 3 and Metro Last Light.
When playing games that run at very high frame rates, the effects of FreeSync aren't quite as noticeable. We're sure if you stopped and stared and looked specifically for visual artifacts, you'd find some, but during actual gameplay they are not always noticeable.
When playing more taxing games, however, with frame rates that may fluctuate above or below 60 FPS or so, the effect FreeSync has on the on-screen imagery and / or lag is great. Disabling V-Sync may eliminate lag, but tearing is evident. And enabling V-Sync may eliminate the tearing, but the lag can be annoying. With FreeSync, the on-screen images don't suffer from visual artifacts and the tearing is also gone.
We wish there was an easy way to visually convey how adaptive fresh technologies like FreeSync and G-Sync affects on-screen animation, but there isn’t. We don’t have a means to capture DisplayPort feeds and shooting video of the screen and hosting it on-line doesn’t capture the full effect either. In lieu of an easy visual method to show how effective adaptive refresh rates can be, you'll just have to take our word for it.
We should also mention that simply using a higher refresh rate on your desktop is also great. There is a noticeable improvement when mousing or even moving windows around the screen, even at the LG 34UM67's 75Hz. If you're the type that gets headaches when looking at a 60Hz screen for too long, higher refresh rates may also help with that.
one review has stats and charts. the other has "feels". feel free to go with the second if you dont care about the actual science behind these two technologies.
a "good" review would be putting a freesync monitor next to a crt and film it on high speed camera. measure the input lag of a mouse factually and not limit yourself to "it feels fine". because in many applications i would not be able to "feel" the lag which is, nevertheless, affecting me. just because its not "visible" it doesnt mean its not there.
It's not particularly in-depth and by their own labeling subjective but that doesn't make it "BS". Maybe they don't have the required equipment. I agree some more data would be better but subjective analysis has it's place.
Feb 19, 2009
10,457
10
I hope the other monitors will be significantly better than the LG. 48 minimum FPS to keep freesync running is rather high. Also looking forward to highspeed cam compares between freesync and gsync.
Yes certainly, plenty of taxing games can go below 30 fps even. I'll wait for better monitors with a lower min hz.
therealnickdanger
987
The only negatives I can see with the LG 34UM67 is resolution (too low for my tastes) and frequency range (48-75Hz). Also, the reviewer doesn't seem to understand how movie scaling works:
"The panel's 75Hz rate and decent response time meant there was no visible ghosting either. If you're viewing content with a 16:9 or 16:10 aspect ratio, however, you'll end up with large, unused portions of the screen, like you see in the 4K Avengers clip above."
You can't fault the display for user error. 21:9 is very close to 2.35:1 (standard cinema widescreen format). You have to have a borderless video file in order to avoid letterboxing (black bars on top and bottom). Even then, if the video doesn't have the exact same ratio as the screen you will still get pillarboxing (black bars on left and right). MPC and VLC can overcome these issues by offering zoom/scaling options that crop out black bars during playback. Also, playing back 24fps content at 75Hz is a bad idea. Set the display to multiples of 24Hz (48 or 72) otherwise you'll get frame stuttering.
Which leads into my next question: wouldn't playing back full screen film or video content result in the display synchronizing to the movie frame rate? Seems like something MPC, XBMC, VLC, etc. should work on to force FreeSync/G-Sync displays to match content frame rate (24/30/48/60/etc.) or offer multiples of it. NO MOAR pulldown and frame rate conversions!
Noctifer616
380
I am not sure, but I think AMD said in order to get FreeSync working with video playback you need the windows media player or something like that. In other words it's not something that can work on every player.
Not 100% sure on that though.
DigDog
13,726
2,253
ok i'll grant you that and i take back the "BS" comment.
"i would like a more technical analysis of the effect Fs has on this monitor"
therealnickdanger
987
It may be something as simple as enabling GPU-enhanced playback through MadVR or something? I know that XBMC has the ability to automatically change the resolution/refresh of the display to the content being displayed, but it's not a dynamic change like FreeSync/G-Sync offer.
EDIT: looks like people are working on it:
http://forum.doom9.org/showthread.php?p=1704883#post1704883
Creig
13
More of a preview than a full review. But at least it's another 'hands on' of FreeSync.
http://www.tweaktown.com/articles/7042/amd-freesync-lg-34um67-preview-things/index.html
As for FreeSync, so far I loved it. If you've ever used G-Sync, it's going to feel identical to you - but for Radeon GPUs. If you haven't used G-Sync, and you're a gamer, then I urge you to try it. Once you've used FreeSync, you're not going to go back. It's just so incredibly hard. It would be like using a ball mouse to one of the new mice on the market from a company like Corsair, and then going back to the ball mouse - it's a resounding no.
Wrapping things up, I'm quite excited about spending more time with FreeSync and the LG 34UM67. FreeSync is something AMD has needed for a while now, and it finally puts them on even ground with NVIDIA and their G-Sync technology. According to reports, FreeSync will be on more monitors by the end of the year than NVIDIA will have G-Sync capable monitors, which is something else that is equally as exciting.
Noctifer616
380
One should note that FreeSync is not usable on the Windows desktop and needs fullscreen exclusive mode to work, which makes it incompatible with most video players. That said, the video player bundled with Windows 8.1 and Windows 10 is FreeSync compatible and the refresh rate will adapt to the video format, thereby ensuring perfectly smooth playback.
That's probably the quote I mentioned. Works with WMP in 8.1 and 10. I hope it will work on other players in the future.
ocre
1,594
7
I am glad to finally see this. It is a great thing of all of us. The fact that it took so much time points to freesync being not so easy after all. But it looks like AMD sure pulled it off
Really glad to see this!!!!!!
therealnickdanger
987
Likewise, I hope there are options in those players to double/triple frame rates for low-speed content (24fps/30fps). I'm not looking for frame creation/interpolation, just 2:2/3:3 playback like movie theaters and most televisions do. Combined with a refresh rate in lock-step, this would be quite a boon to the HTPC segment.
Subyman
Moderator <br> VC&G Forum
Mar 18, 2005
7,876
32
86
I hope nvidia moves to free sync. I'd like to be able to swap cards without swapping monitors. I wonder if there will be monitors that offer both options?
AnandThenMan
3,979
589
LOL@ Ryan's twitter. He seemed a little butt hurt, or is it just me? Either way funny stuff AMD breaking their own NDA.
I hope nvidia moves to free sync.?
Nvidia doesn't have a choice, I think they will hang onto G-sync as long as possible but ultimately will have to embrace F-sync.
Subyman
Mar 18, 2005
7,876
32
86
I'm thinking pressure from monitor manufacturers may force their hand. Having to split SKUs can be costly for monitor manufacturers. Would be much easier to not have to have a gsync AND free sync offering and instead just have the "gaming" model.
Vesku
3,743
28
86
Well, promoting someone breaking their NDA, bit of an oops right there. Was wondering where the other sites reviews were.
Destiny
2,270
Overclock3D Review for the Acer XG270HU 2560x1440 144Hz is up! I will add more to the list for the OP if anyone finds more reviews and post to this thready.
Thank-you in advance!
Despoiler
1,967
772
From the Anandtech review.
The major scaler companies (Realtek, Novatek, and MStar) have all announced support for Adaptive Sync, and it appears most of the changes required to support the standard could be accomplished via firmware updates.
It looks like what I've been saying since A-Sync was announced is correct. Vindication feels good.
xthetenth
1,800
529
Excellent news. Looking forward to it, widespread adoption can't come too soon. Hopefully it just becomes a thing that monitors have rather than being a standout feature that can justify a premium.
AnandThenMan
3,979
589
Going forward more and more monitors will use the A-sync capable scaler, I would imagine eventually all displays will have it. So really there is no excuse for Nvidia to keep promoting G-sync, it offers no additional benefit and costs more to boot. And it can't be used on a notebook easily if at all.
What Nvidia might do is use A-sync and rebrand it G-sync. Not sure they can do this but if they can I think they will.
ShintaiDK
20,378
145
Seems the penalty is substantial if you cant handle the minimum FPS range.
http://www.pcper.com/reviews/Displa...chnical-Discussion/Gaming-Experience-FreeSync-
And because the minimum variable refresh rate is 48 FPS, and probably the worst judder comes within the 35-45 FPS range on a monitor with this configuration.
They really need to get down to 20-30hz.
With the two working FreeSync monitors we have been testing over the past week or so we did notice ghosting of the animated images was prevalent. Our first monitor was the LG 34UM67, an IPS display, and thus we actually expected a bit more ghosting than our comparable 144 Hz TN panels. But we actually see a similar effect with the BenQ 144 Hz TN FreeSync monitor as well.
