Looks like I'm sticking with 10.12.
Fable III resolves negative CrossFire scaling
Changing from 10.12 to 11.1a hotfix has increased my idle clockspeed from 100Mhz to 300Mhz on the core, with the memory still at 300Mhz like previous driver. Anyone else notice this?
The game's not scheduled to launch for at least one more month. Props to AMD for being ready for it :thumbsup:
Is everyone installing the 11.1 drivers or the 11.1a hotfix drivers. I believe it was the hotfix drivers that had the performance enhancements. Are they the same?
Im downloading them from here http://support.amd.com/us/kbarticles/Pages/AMDCatalyst111aHotfix.aspx
Where can you get new game profiles, specifically for xfire?
Thanks, i'll install the latest 11.1.a drivers, and then watch that to see if either get updated.I assume 11.1a has the latest profiles.
as gaiahunter said the profiles are separate.
Only Xfire profiles are separate. (just found that out myself)But the latest drivers come with the latest profiles, right? If not, no big deal.
I'll have 6950's in xfire, so i'll get those profiles. Do I need to apply them separately, or does it automatically happen?
And everyone else should use the official 11.1 drivers.
Yes, install 11.1a drivers first, then the profile package.After 11.1a I assume.
According to this , yes.I have a 5870. The 11.1 drivers do not enable MLAA (morphological filtering).
Does 11.1a hotfix provide MLAA for 5000 series cards?
Best i can do is try to install the 11.1a drivers on my laptop with a mobility HD5870.I have a 5870. The 11.1 drivers do not enable MLAA (morphological filtering).
If not, can anyone advise how to enable MLAA on 11.1 drivers?
Ok, i could not get the 11.1a drivers to work with my mobility card.I have a 5870. The 11.1 drivers do not enable MLAA (morphological filtering).
