IN this world record . LOL only 1 module was used. None of the AMD fanbois will except this as 8 cores 4 modules is the all everthing . Unless these AMD guys swing back and forth.
Then point out that H50/H60s/Antec 620s and $50 Performance air Coolers can get you to 5GHz on Bulldozer with the code word "simple"
and then with H70/H80/H100/Antec 920 and $75ish High-end Air Coolers can get you beyond 5GHz
No idea on custom water loops though
But, No facts till release :whiste:
Really this was only 2 threads . What bench marks were run . I have a $100 says my 2500k would beat it @ 4.5 ghz and my 2600k@5ghz would cream it in Cineabench 11.5 . Any takers?
It was done on a dual-core module, no benchmarks were run the OC was a suicide run.
Try turning off HT and Cores and do this you get a burnt chip, supposedly not sure if it was a rumor or fact
And since none of the current gen Intel CPUs have ever busted the Pentium 4 WR clocks having AMD just waltz right over it with a processor with half the stage pipelines(31-stage pipeline vs 16-17) of the Celerons while also having double? the transistors
