Originally posted by: KF
>I'm fairly certain the reason the clocks aren't going very high is because K8 is basically
> a modified K7, which ALSO apparently has a 2.2GHz clock ceiling..
It is time to become uncertain.
There is nothing much in common with the K7 die, because there can't be. SOI is a completely different way of building chips that uses different chip processing. A complete redesign would be necessary to manufacture even an identical logic circuit (whch the K8 isn't). The reason for using SOI is to reduce substrate capacitance, which in turn enables an otherwise identical circuit to operate at much higher speed. SOI processes are much harder to execute, which drives up the cost. SOI has not been used at the level of complexity together with the small design rules of the K8 chip before. Therefore working out all the bugs in the processes to get chips as perfect as they need to be to operate at maximum speed is going be difficult. There is no garantee it can be done successfully. The same can be said for any process pushed to its limits. AMD is spending huge sums of money on new sorts of equipment to get this going. Whatever clock speed they are shipping is the result of how close to ideal they have been able to get. Because of the nature of SOI, if the design were identical to the k7, the clock speed would go much higher, provided the quality of processing required can be achieved. In short , if the K7 maxes at 2200 GHz, then the K8 with SOI maxes at something much higher. Let me repeat: the ONLY reason for going the SOI route is to get much higher speeds. It is otherwise a total waste of money.
The K8 is an elaboration of the K7 in conception. In actual implementation, the CPU resources are designed to go to higher speed. Since the underlying process it is carried out in are inherently capable of higher speed, the speed of the K8 will go much higher provided AMD can execute the process engineering. I know people think AMD should try to "stomp" Intel, and if AMD doesn't, they are failing. But realistically the more margin of performance AMD strives for, the more it costs them, so the only economic thing to do is to slightly out-perform (if possible). Intel hasn't been sitting still, so the fact that AMD is achieving parity even with the K8 delays is excuting pretty well.
