AMD Athlon XP 1800+ Overclocking Help, PLEASE READ!!!
dguy6789
OK, I have an AMD Athlon XP 1800+ Throughbred B. It default runs at 1.53Ghz with 266FSB and 1.5 Vcore. I have several questions. I plan on my water cooling system to get here tommorrow, so assume i will be running water cooling.
Right now I am running it at 1.66Ghz at 333fsb at 1.5 Vcore.
1. I know vcore increases speed of the electricity to the processor, higher vcore can allow for higher overclocks correct?
2. I also heard vcore can reduce the life of the cpu, if it does, how much would the life be reduced if i go from 1.5 to 1.75?
cpuid has the following information, would this help for nay of you to tell me how much this baby could OC?
Codename: Thoroughbred
Package: Socket A
Technology: .13m
Specification: AMD Athlon
Family: 6 Model: 8 Stepping: 0
ext family: 7 ext model: 9 revision: A0
instructions: MMX(+) 3DNOW! (+) SSE
Clock speed: 1670.5 Mhz L1 Data: 64 KBytes
Multiplier 10.0X L1 code: 64 Kbytes
FSB 167.0mhz level 2: 256Kbytes
bus speed: 334.1Mhz
please give me an esitmate on how well this will oc with water cooling. The max i could do is 12.5 X 166, because my memory ios pc2700 and i dont want to mess with the cpu to unlock more multipliers, and i dont want me and fsb to go out of sync please help me out.
thats right, increased vcore always the chip to be more stable when overclocking
i wouldnt worry about 1.75V, even 1.8V. most people dont go over 1.8. almost everyone does not go over 1.85V
Yep, i wouldn't sweat 1.75, or even 1.8 I would think if a CPU is good for 10-15 yrs that it could at least make it for 2yrs+
Plus, who uses them after that 😛
