AMD A10-7850K preview at Asus A88X PRO
Status
Not open for further replies.
FlanK3r
312
36
I must CPU return back, so today quick OC tests (later or tomorow here...)
SPBHM
4,932
321
llano vs richland vs kaveri OC could be fun,
I remember 3870Ks could run at 3.6/900MHz, Richlands what? 4.8/1000?
FlanK3r
312
36
Richlands can run around 4800-4900/1100 :).
Kaveri from my review 4550 MHz/10XX MHz stable, for CPU benchmarks I can go higher a bit (4650 Mhz). But SUperpi is very hard after 4800 MHz at CPU.
FlanK3r
312
36
1.455V for CPU, 1.3V for iGPU = 4544 MHz and 104x MHz iGPU, 30min stress test
Cinebenchr R11.5
3D Mark11, seems limitation of APUNB and memory. I think, this clocks of iGPU needs more juice from memory. 2666 MHz at least.
More tests tomorow :)
AtenRa
13,298
2,108
^ nice thanks ;)
Hmmm, faster than Richland at 4.8GHz in Cinebench 11.5 good job :thumbsup:
FlanK3r
312
36
So gonna for some OC test...and few interestings. This is not full version of review, but most of them is here now. SOme clock to clock comparison, win7 vs win8.1, more OC and HSA tests will be in official review next month.
First we talking about autooc. Asus give me 4200 MHz and 960 MHz at iGPU part. This is not bad. Nice things for beginners and people scared from BIOS settings :).
3D Mark11
AIDA GPU test
wprime 1.55
Max stable OC for CPU and iGPU
In AMD Overdrive stability test I got 4544 MHz and 104x MHz at iGPU part R7. For CPU I needed decent 1.455 V in BIOS and 1.315 V for APUNB (iGPU). Im sue, 4600 MHz is possible, but with very high voltage. So I left only 4544 MHz. iGPU is very strong. Im limited RAMs. First low clock memory for this GPU engine and second Sammi from AMD told me about single sided limits for iGPU score. Unfortunatelly, my RAMs are single sided :).
3D Mark11
AVP benchmarks - these benchmark is harder than real game of AVP. You can try it.
1920x1080, high settings, 16AF, tesselation
1920x1080, medium settings+tesselation
1680x1020, medium settings+tesselation
FlanK3r
312
36
Wprime 1.55
Cinebench R11.5 - single and multi CPU score
Cinebench R15
Fritzchess benchmark
Truecrypt
x264FHD test in 1080P
Superpi 32M (as 5100 MHz Richland)
FlanK3r
312
36
demonkevy666 wanted what about cores unit. I must CPU return back, until Il have new only for me :). But I benchmarking two test for you :D
First 1CU/2C, so classic one module
All test I did with 4 GHz clock, Cinebench R11.5 and Fritzchess benchmark
Now 2CU/2C, so two modules with two active cores
We can see, 2CU/2C is really better!
Others tests:
3D Mark Vantage, CPU stable clock, iGPU autoclock
Cinebench R11.5 at 4645 MHz
Cinebench R15 at 4645 MHz
FlanK3r
312
36
Superpi 1M at 4793 MHz, I had run with 4850 MHz, but worse score...
Superpi 32M at 4799 MHz, this score is as 5300 MHz Richland :), Kaveri is in 32M very effective.
What about power consumption?
I was not surprised about lower consumed number in load. But higher idle. Why? I do not know, maybe BIOS or board, Richland and Trinity I tested with another board...Remember, I use high PSU 1200W Corsair for test, with normal 350-400W PSU will be value lower.
After OC is Kaveri really quicker than OC Richland, in all test is winner, sometimes very clearly (wprime, R11.5, superpi, 3D Mark, AVP) and with lower power consumption.
Slomo4shO
586
I should be getting my 7850K sometime this weekend and it will be going under water. Using a UD4 and pairing it with a couple R9 290s. I also have a 7790 on hand to see if it would hybrid crossfire but I will likely wait until the beta patch is released to venture into Hybrid Crossfire benchmarks.
SPBHM
4,932
321
nice results, thanks for posting, the 3dmark results are not to different from what I remember the 5770 doing,
it would be interest to see GPU OC only power usage increase compared to stock.
(does the 7600 allow IGP multiplier OC?)
inf64
2,966
1,436
@ FlanK3r
Thanks for the update, great review :)
@ Slomo4shO
I expect you to create a topic and cover everything in details :)
el etro
1,581
14
The ordinary forums user/PC User usually do not understand anything, that is very important in the "big company OEM PC configuration business".:biggrin:
This.
So now reviews are rejected and cherry picked samples from multiple reviews (spot the irony) are applied in force to save AMD's PR?
Who would have guessed? ^^
You from CPU boards deal with this BS too? :mad:
Markfw
CPU Moderator, VC&G Moderator, Elite Member
20,116
7,597
This is locked until the upper moderators decide on a permanent action.
self-promotion is not allowed.
Status
ASK THE COMMUNITY
