your 2400+ will run w/ k7s5a pro and 512mb pc133
since you're a rookie
P) there are some things you should know
there is a lot of confusion with the naming specifications in our computer world today
the 2400+ runs on 266mhz fsb
the 2400+ is actualy 2.0ghz (15 x 133) but it is rated as a "2.4ghz" cpu
the bus is 266mhz, however it is double rated, meaning that it actually runs at 133mhz
your pc133 will run with the 2400+ at its rated speed, you wont have any performance loss
pc2100 is something along the lines of: "your memory will move data at a speed of 2.1gb (pc2100), which is roughly equivalent to 133mhz)
therefore pc2100 ~ pc133 in terms of speed
but performance is not...
