- May 6, 2001
- 237
- 0
- 0
Am I stupid, or could there be some other explanation? I got a 512mb stick of this Kingston HyperX PC4000 the other day, stuck it in my rig and all I can get is BSOD if I go over 208. Here are the cast of characters :
GA-7N400 Pro2 F8 BIOS
AMD Athlon 2400+ mobile
1 stick Kingston hyperX KHX4000/512R
TTGI 350W PSU
The system was running fine, Prime95 stable with a stick of GEIL PC3200 at 12.5 X 200 FSB for 2.5ghz, but I thought with the good deal on the Kingston ($99), I might lower the multi and up the FSB. Now I can?t get it to run at anything over 208FSB. I have tried;
12.5x208 = system freezes up
12x210 = OK with +.2v overvolt, but not so stable
12x213 = freeze
11x200 boots as 3200+
11x210 freeze
11x209 freeze
11x208 freeze
11x208 +.1v DIM overvolt and it works OK, but at 209 it will not boot to windows.
11x209 +.2v DIM overvolt and I get BSOD
this board only allows +.2v overvolt on the dimm, so I can't go any higher, which is suck because the GEIL is rated for 2.9
So what is the deal? Did I get a bad stick? Am I doing something wrong? Or can the CPU not deal with a FSB higher than 208 and it has nothing to do with the RAM?
Any suggestions?
TTGI 350W PSU
12x213 = freeze
11x210 freeze
11x209 freeze
11x208 freeze
Any suggestions?
