put together the computer yesterday, and noticed that my CPU is running at 1250mhz instead of 1670mhz. I have a AMD 2000xp+ cpu on a MSI KT3 Ultra mobo.
I just set this board up last night with an XP 1800+. You need to change the FSB in the BIOS to the 133mhz. The default FSB is 100mhz. I don't think there is a jumper on the board to adjust FSB.
Go to amdmb.com and find the MSI forums. Lots of good tips for setting up the KT3 Ultra.
