AMCOR PLM14000E 14000 BTU Air Conditioner - Retail
Patented Evaporative Booster Technology - During the cooling process, water is extracted from the air as it passes through the unit. Most of this water is used to cool the unit and make it run more efficiently. This unit has a built-in water tank (not removable) with a drain outlet. When the tank fills, the compressor stops running. This indicates that the tank should be emptied. Included with the unit is a window mounted exhaust kit. AC must be vented via exhaust hose and window kit (included).
Note: If your room has a heat source such as direct sunlight or computer servers, the AC coverage area may be reduced.
Features
* Unique Patented Evaporative Booster for more efficient cooling
* Backlit LCD control panel
* 3 speeds (2 fan plus one turbo)
* 3M Filtrete filter: removes dust, pollen, bacteria and animal dander
* Activated carbon filter helps remove odor
* Washable air filter collects large dust particles and prevent bacteria build-up
* Built-in castors for easy moving
* Full thermostat control
* Programmable timer (24 hours)
* Adjustable louvers to control air flow
* Extendable exhaust hose (up to 5 ft.)
* Adjustable Plastic window venting kit
* Remote control with LCD display
* Power Consumption Cooling: 1100W/9.8A
* Moisture Removal: 80 pints per day
* Thermostat Range: 64F ~ 90F
* Power Supply: 120V / 60Hz / 1 Phase
* Max Room Size: up to 400 sq.ft.
* Refrigerant: R22
* Dimension: 20?W x 16?D x 33?H
* Weight: 75lbs.
* Warranty: limited 1 year and 5 years on the compressor
$329.99 shipped @ newegg after $100 rebate
$100 Rebate
Features
* Refrigerant: R22
* Weight: 75lbs.
$100 Rebate
