Rakehellion
- Jan 15, 2013
- 12,181
- 35
- 91
,.. you quoted me,.. but, didn't seem to understand this part,.. So, here is a 2nd pass.
"At all costs." So $10 to $15 isn't the actual problem, it's some passive political stand. Got it.
Any item with a fixed shipping cost is the same as free shipping. it is priced with a gimmick to get people buying it for either the lower pre-shipping price (like a case w/ $20-30 shipping), or because of free shipping (even if it has to be Egg saver).
If you get items that don't have such fixed costs, they add up by weight, after the initial minimum. IE, you might start with $7.68, and after adding another 5 things, it'll be $12, despite each thing showing up with a normal cost, like $7.68 (because that would be the cost of only getting that one item, which of course is higher than getting more).
If shipping is not flat rate or free, it should vary nominally with weight, size, and item count
Because it differs from past experience using Amazon, and is not stated anywhere (I quoted what little that was stated in the OP, and no seller pages had anything clarifying it for any specific seller). For example, if you buy from Amazon themselves w/o FS, shipping does not stack per item the same way, but instead adds up by volume/weight like most other places. I don't recall it doing that in the past from Amazon sellers, either, but it has been quite awhile since I've done an order using sellers through Amazon with many items (usually I'm doing that kind of order directly through Amazon).Why would you assume shipping would be anything other than the stated price? That's your own screwup.
Monprice? Since when. I ordered from them just a few months ago, and the S&H costs had a typical small nominal increase per item. Same with Newegg.monoprice
Sucks for you. Some of the best deals on Amazon come from the affiliate buyers.
Not when they charge you the savings in shipping - which is not always, but pretty common (as noted as well by someone else in this very thread).
But, thanks for your armchair sourcing and procurement guidance.
Is that like a lemonade stand?
Or, were you trying to say stance?
You seem to assume that they always do. Sucks for you. Even with shipping the deals can be better.
And among the reasons I don't have it. Not $3.99 specifically, as that's just a minimum, but When finding a few items to buy on Amazon, I often end up with non-Prime items or buying from selling not doing FBA/Prime. I don't pay anywhere near $100/yr from them as-is (could have, today, thoughThese $3.99 third party charges are not to get you to buy Prime. They're the same with Prime.
He doesn't care about price. He' s boycotting all Amazon sellers because some overcharge for shipping.
No assumptions needed - there is section on the top right, which sums up everything nicely:
1) the price they charge for the item
2) the price they charge for shipping
The price they charge for the item is indeed usually lower (SAVINGS!), but, the price they charge for shipping is usually the exact amount they 'saved' you. And, if that is the case, I might as well just buy direct from Amazon, specifically for Prime eligible items.
If the 3rd party seller did indeed want to save me money, they would not be charging me that SAME amount in savings from the item, on shipping. It is not savings. It is a wash. It is an attempt for the 3rd party seller to come up as #1 in best price.
3rd party sellers on Amazon.com are dirt bags and they will not get my money. You can give them all you money,.. but, I am not sure what crawled up your exhaust pipe for what I choose to do with my money.
