Nope. The size of the motherboard shouldn't really affect anything.
The size of the case will, though. A mATX motherboard in a mATX case will probably have worse cooling than a mATX motherboard in an ATX case. This is simply due to the fact that the ATX case is bigger and thus should be able to hold more fans.
