- Oct 11, 2007
- 1,163
- 4
- 81
I have a box I'm using for an unRAID server, and I'm trying to make it as quiet as possible.
I already replaced the 120mm exhaust fan with a Gentle Typhoon, and I replaced the 80mm HDD cage fan with a low rpm, quieter version.
The noisiest remaining fan in the case is the 70mm fan from the stock HSF.
The CPU in the box is a 45W Athlon II x4 that I have underclocked to it's Pmin frequency and voltage (800MHz, 0.875V). I think its cool enough that I can passively cool it (even the stock HSF doesn't get warm), but I'm wondering what my best options are for coolers.
Of key importance to me:
1) easy to install/remove - I hate screw-on/through-hole type coolers, I want one that easily attaches to the stock AM3 mounting bracket
2) cheap - no more than $40, preferably under $30
3) Good enough cooling - I don't care if the CPU gets a little warm, but I'll probably want one of the rifle-style coolers so the 120mm exhaust fan moves some air through it.
Recommendations?
Recommendations?
