Hello all. I am about to upgrade my CPU (AMD AM2+ sockets, 9950BE to AMD 965 and 1090T) in two of my PCs, and have decided to get a new CPU heatsink/fan for both as well.
I am currently using a Sunbeam 92mm and Sunbeam 120mm Core Contact Freezer. I decided that I would like to get a new heatsink/fan for my new CPUs as I found the installation of these very difficult, and damaged the heatsinks a bit during installation. So I would like to buy a new CPU cooler that is easier to install.
I have been considering the XIGMATEK LOKI 92mm. The installation itself seems very simple, but I am wondering which way the fan points? I can not find a picture of it installed in an AM2+ case. Is it mounted so that it blows the air into the rear case fan? Here is an illustration (different heatsink/fan than the XIGMATEK):
http://images.bit-tech.net/content_images/2009/08/five-lga1156-coolers-tested-on-lynnfield/tx3.jpg
Here is the specific XIGMATEK LOKI 92mm I am looking to buy:
http://www.newegg.com/Product/Produc...igmatek%20loki
Anyone have any input on the XIGATEK in terms of quality, noise, and cooling? Seems very new and not a whole lot of info on it.
And I have never removed a motherboard before. Any tips on what I should or shouldn't do when removing a motherboard?
And finally, I have some TX2 thermal paste. What is the best method of applying it to this LOKI?
Thanks in advance for any help.
