ViviTheMage
Yeah, the x200 is a bit older...but :
- 12.1" TFT display with 1440x900 (WXGA+) resolution (LED backlight) 250 nits
I was in the same boat as you ... I bike around with my x220, sucker lasts 13~ hours with the 9 cell and an i7 2420m.
I can DEAL with the resolution, because of the epic battery life, usb3, 12.5", full keyboard, IPS panel....and man, my SSD runs very fast in this little guy.
Yeah, I guess that all those positives are awesome, but things I don't personally care about or need; I really only need it for 4-5 hours per day max. One thing I was considering, actually, was seeing if I could *downgrade* the t420s battery to something lighter, lol. But now I'm really being rediculous, I know.
Asus announced the UX21 this week. No idea what the resolution of the screen is, but It's an ultra thin laptop with an i7 processor 2.1 pounds (lighter than the Macbook Air), USB 3
It should be out sometime this year. (September is the rumor)
You have a set of requirements, stick to them ... resolution was maybe in my top 5....I wanted high battery life, usb3, i7, and IPS panel...before I cared about resolution a whole lot. Do I wish it was higher ... yes, but the laptop is just amazing for what I wanted.
Exactly, 5 pound is nothing in a backpack until you have to carry said backpack for the entire day/traveling. Which is why I thought Vaio Z is worth it. When you carry around photography equipment, any amount of weight you can reduce is worth it.
Snug, just a drive by comment here.
Unless you are doing CPU intensive multitasking (like video conversion, structural analysis, or folding) you REALLY do not need much CPU power.
HD and Memory will make things run much faster than the CPU in most cases.
The only other thing I would suggest to do a backup of your old machine and do a clean install. See what happens to the performance. If you see it jump up, then you know it is bloatware, not CPU that is your problem, and any machine will have similar problems after a time (apple less so simply because you can't INSTALL some of it w/o having a virtual windows environment...).
I am not jumping into the whole Apple battle, but I just hope you find what you need.
BTW guys, 5lbs is nothing in a backpack, but why carry an extra 2-3 lbs if you really do not NEED to? Don't answer, just a rhetorical question, but think about it a bit. If he CAN go smaller, why not? (IF he can...)
Here's what I want:
- light and thin. I bike around and every pound/inch matters
- fast enough for multiple windows/applications open w/o crawling (eg, no netbooks)
- higher than 1360x768 resolution
- ideally with ssd but this is not required
So far:
- x220, screen too low rez, same with x1 and samsung series 9 whenever that comes out
- t420 too heavy (I think)
- t420s still kind of heavy for the price, sheesh!
I'm at a loss for other contenders. 12/13/14" is fine, but the resolution is pretty important to me - what is the deal with the PC side?!? It's honestly crazy that lenovo and samsung can't provide a 1-to-1 feature competitor with the air.
Or did I miss something obvious?
Only 64G though, so if this is ALL you have on it, it may not be enough....
Yes, you're missing the new Macbook Air coming out in a few months.
OP I have found myself in a similar situation as you. I am on the lookout for a new notebook but still can't find quite the perfect thing. In my case my requirement were:
1) 13-14" size, less than 4 pounds. Closer to 3lbs would be better.
2) At least halfway decent display quality. This one is the hardest! I'd like something a little higher than 1366x768 but I'd be willing to take that res IF...it had at least decent color accuracy and contrast.
3) Backlit keyboard
4) < $1300
Those are my hard requirements. Everything else I'd be flexible on. No optical drive is fine. No SSD is fine (I'd add my own anyway). No discrete graphics is fine (i actually prefer intel graphics to keep power down and battery life up).
Heck of a time trying to get all though things at once!In may case about the closest thing so far is actualy a 13" macbook pro. It's a little heavier at 4.5lbs but has a decent screen (16:10 bonus also). The samsung 900 series is actually an even better match (though screen quality is unknown)....but the price is ouch!
Screen quality is not resolution, I can't believe people don't understand this.
The Macbook Air's screen is absofuckinglutely blow your ass out of the water STUNNING. It has little to do with its resolution, but its display quality, contrast, and brightness. .
That's why people keep suggesting the ThinkPad x220, it may not have the highest resolution screen but it does have an IPS panel unlike the Air.
