Well, after partitioning a brand new WD 120JB for a new system, (aquired for $44 AR/AC @ OM) and copying over all 60 gbs of my data (music, progs, documents etc) to the data partition, I set it down to finish building my new system. The original drive I had copied all my data from was formatted and installed as the main HD in my girlfriends new budget system. There goes that.
Then, before I even get a chance to install the 120JB in my new system, I inadvertantly bumped the bare drive off the side of the bed where it fell to a bare tile floor from no more than two feet. When I have it in my new system, the bios recognizes it as a WD80BB, (which of course is wrong) but it does not show in windows or even a dos prompt. Booting with the data lifeguard disk does not recongnize or fix the disk either. (am i doing it right?) Worst of all when i hold the drive up to my ear and wiggle it back and forth a couple times it sounds like something is loose like an unparked head skimming over a platter?
I guess my question is, has this happened to anyone and is there any "quick fix" or something I can try to get that head reaparked (assuming thats the problem). I've tried the drive in multiple machines with the bios still recognizing it as only an 80 gb, rather than 120 gb HD, and the OS not showing the drive at all, not even in disk managment. Any programs to download or anything?
or am i just screwed.
maybe I should drop it again..?
i guess i can at least return to OM, or take advantage of the WD 3-yr warranty. and there goes all my data. *sniffle*
