Hi all,
Just upgraded to the Q6600 Quad Core. My idle temps with stock HS and fan are in the low 50's, and under load hits high 60's, even cracked into the low 70's today. I've tried making sure that the heatsink is as tight and flush as possible, and even took the side case door off and blew a small highspeed fan into the case right at the cpu, but nothing I do seems to bring the temperatures down. I noticed that other stock setups that are not overclocked like myself run much cooler...usually in the 40's at idle and high 50's to low 60's under load.
I have a decent Apevia case with one fan one the top and two in the back pulling air out of the case, plus another real small fan inside the case pointing at the fan up top, to help push air out. Also, the temp inside the case is usually in the low 30's. Despite all this, the temps are staying where they are; can't get them to go down.
Just a shot in the dark, but I'm wondering if this may have anything to do with my situation.
In addition to upgrading from the E6300 to the Q6600, I also upgrade from stock integrated graphics to a GeForce 8500 NVIDIA GPU, and added an additional 2GB RAM, but I have not yet upgraded my stock 300w PSU. Is it possible that I am "overworking" my PSU, causing things to run hot? I am putting in an order for an ASUS fan/heatsink and a 500w PSU, as well as a Gigabyte mobo with the heatpipes all over the board this week, but in the meantime is it safe for me to still be running the stock PSU?
Thank you in advance for any help or suggestions.
