Am i running dual channel?
Weenus
Ok i have to sticks of identical ram, is there a way i can verify that my ram is running in dual channel mode,? =)
My mobo does have the dual channel capability.
t.y.
use CPUz it will tell you !
And I think if there in the right slots and not giving any errors you are indeed running in daul ! but use CPUz to check to make sure.
I've actually seen my bios report Dual Mode during boot screen to tell you it is running dual channel.
If not make sure you stick the ram sticks in like colored slots.
