Alright, I'm having a few minor crashes every so often, however, I believe that they're due to software issues. Either way, I got to thinking and was wondering if maybe they're being caused by power ripple, which I've heard can damage components and cause huge instability issues on machines. So, just for fun, I pulled out my multimeter and ran some tests.
While idling at the Windows desktop, my PS is putting out the following voltages:
+5V - 4.96V
+12V - 11.94V
As long as I'm idling, my multimeter is unable to detect any ripple. I loaded up 3DMark03 and started copying a bunch of large files between drives, and saw my voltages move a little. My +5V stayed pretty steady, and fluctuated very little. Every so often, it would move around a bit, and was always in between 4.93V and 4.96V. My +12V rail was a little bit more jumpy, and was moving around a bit. The +12V rail was always in between 11.82V and 11.94V. It wasn't going crazy or anything, but as I put load on my machine, it gradually moved down to 11.82V, and as I let up on the load, it gradually went back up. When I say gradually, I mean it took about 10-15 seconds to get from 11.94V to 11.82V.
So, here's my question: Is this amount of power ripple enough that it could be causing problems in my machine? I'm not just talking instability, is it likely that this will eventually damage my components? All the voltages are staying within spec, but I know ripple can be very detrimental, even if the voltages are within spec.
Any help would be much appreciated, as I'm thinking about going out and getting a better power supply to throw into this machine. Also, machine specs (it's not posted in my rigs):
2.8GHz P4 C
Intel 865PE reference board
800MHz FSB
300W PS (I'm looking at upgrading to a 430W Antec TruePower)
256MB DDR400
ATI Radeon 9800 Pro
48X Lite-On CD-RW
16X Pioneer DVD-ROM
60GB 5400RPM WD HDD
80GB 7200RPM Maxtor HDD
Turtle Beach Santa Cruz
56K Modem
Onboard NIC
Thanks again!
- Jacob
+5V - 4.96V
+12V - 11.94V
2.8GHz P4 C
800MHz FSB
256MB DDR400
ATI Radeon 9800 Pro
48X Lite-On CD-RW
16X Pioneer DVD-ROM
60GB 5400RPM WD HDD
56K Modem
Onboard NIC
Thanks again!
- Jacob
