Long story short, I have this old 20" box fan from Air King that was my parents before I was born. The thing is all steel, aluminum blade, reversable and it ruled. It was made in like 1960 though, and after all these years the bearing seems to be going south, and no amount of cleaning/lubricating will keep it from making awful screeching noises.
I love this fan because it moves a ton of air, and I can put it in a window on the 2nd floor of my condo blowing out and have it create a artificial breeze through the whole house. I went to a few local stores, but any fans they have nowadays seem to all be 100% plastic made in china dealios with weak motors.
Well, I decided to look into fans online, and it looks like Air King still makes some serious fans, but they are pricey.
Their best box fan now is in a metal housing, but the blade and grille is plastic. It does move a decent amount of air..2200CFM on high, but I'm just not a "fan" of plastic fans.
Anywho...I've been looking at this industrial air circulator they make...looks awesome..all powder coated steel, including the blade, and has a high end motor, 20" blade, but it's like 24lbs, and costs about $85.
The fan in question
Specs:
3670CFM on high, 3330CFM on medium, 2940CFM on low.
Motor: 3-speed, 1/6 HP, 120V, 1 phase, totally enclosed, ball bearing, permanently lubricated, permanent split capacitor
Now, I realize this won't fit in my window quite as well as a box fan, but I also would use it as a floor fan.
Now, I know it's pricey, but I want a fan that will last for many many years like the one I have...
So....worth it?
The fan in question
Specs:
So....worth it?
