- Oct 30, 2004
- 11,442
- 32
- 91
Am I crazy?
Previously, my CPU would run at about 39 degrees C at idle and it would get up to about 46 degrees at load. My RAM speed, factoring in the RAM divider, was about 380.
In the past I'd had problems playing Unreal Tournament 2004 with 4 x 512 RAM, so I had had to remove 2 x 512 of it, but I wanted to try again with a lower RAM speed since someone on another forum said that UT 2004 doesn't like the RAM speed over 333 when you have four sticks.
So I reinstalled those two sticks of RAM and I'm using a lower memory divider, trying to keep the RAM speed at or below 333. To my amazement, my CPU temps have dramatically decreased !!! It's now showing 31 degrees C at idle and lately I've seen it at 39 degrees at load.
Obviously, I'm ecstatic about this, but I'd like to understand it.
For Socket 939 CPUs, does running your RAM at a higher frequency increase CPU temp and the strain on the CPU?
