AdamK47
You pay for map updates. If you don't have a DVD player, then you have to go to the dealership to get the updates loaded, otherwise it comes on disk. Typically around $200 for an update from past experience.
The 4G LTE is purely a hotspot and not integrated into the ChevyLink. If you have ATT you can add the service to your shared plan, otherwise you pay for chunks of data. Tried it out, but has little value in a 2 seater. Maybe a family sedan or SUV would be a better place.
Thanks. I haven't messed around with it very much. I doubt I will. I heard that MyLink did have access through a 4G connection for 2015, but that looks like it was delayed.
I just need to know where to find NPR. I'll probably use the nav and phone connection every now and then.
