Am I baking my system?
JBDan
2,333
I have the same thing with my A8V dlx. I think the 125C is what it says when there is nothing to measure, like a default reading of some sort. Dont mind it. :)
superfly27
293
Maybe you can experiment by removing the side panel and putting a 12 inch house fan in front of it to see if there's a difference. Some funnay dude solved his cooling problem like that.
Maybe BIOS update would do the trick?
BonzaiDuck
16,889
2,208
I think you can de-activate the LM75 readings. It would occur under "Configure"->"Advanced," I think . . . .
BonzaiDuck
16,889
2,208
Change that . . . . more likely it would be a command line option.
Send an e-mail to Alfredo Comparetti.
TicoAz
209
Thanks for the replies, I am sure you can diasable the LM75 readings, Before I do I want to make sure they are false... lol
Greenman
22,494
6,580
If anything in your computer was running at 125C you'd know it. The smell and smoke are a dead giveaway.
