DPOverLord
Quick question on my new setup. I finally set up my system and will be installing windows. However before I do this I have a concern on my Thermalright Ultra 120 extreme and HR-05 SLI ( attached to the Northbridge).
My first question is on the CPU Heatsink / Fan:
- I spent a lot of time clamping this Heatsink onto the cpu I used 2 drops on the cpu and 1 drop on the bottom of the Heatsink. I then pushed the Heatsink onto the cpu and moved it around for good surface spread of the Artic Silver. I then clamped it down with the 4 screws to the bottom of the motherboard via the backplate. The issue (or maybe its not an issue) is that if I use my hand I can move the Heatsink a little as its on the CPU. To me this does not seem normal. It does not seem to come off the cpu it has solid contact it just moves left and right a bit. Is there something I am doing wrong?
- My other question is just about the same for the HR-05SLI I used the connector which hooks into the 2 spaces on the motherboard. It was tight however if I try to move the Heatsink it will move a little also.
Please tell me what you think since I want adequate cooling for my upcoming O/C and the last thing I want to do is fry the mobo or cpu. Thanks! I will send pictures when I can in a bit.
