Well I finally got this project started. It's an aluminum duct made from a drier vent part, modified slightly to fit an Alpha heatsink. The fan in the photos has the mount tabs from one side removed. It then fits into the duct and is held tight by the clamp. The fan is mounted to the case normally with four screws...decoupled with a foam gasket.
This is the only mounting for the setup, as on the Alpha end it is a snug fit. I'm still experimenting with different fans....but for now the fan is blowing in at 2000rpm. It's a PCToys stealth fan from CompUSA and fairly quiet. I haven't tried the SilentTec utility(Aopen AX4GE MAX board), so the fan is blowing at a constant 2000rpms.
This setup really looks good in the aluminum Lanboy....The projection on the Lanboy side panel completely covers the mount, while leaving the aluminum part of the duct visible.
The temps are very good. P4 2.66 idles at 33c and I haven't been able to get it much over 37c. Running the SilentTec utility should be able to lower the fan speed quite a bit and still remain cool. We'll see...
Alpha Duct in Lanboy
