- Apr 17, 2004
- 17,555
- 1
- 0
UPDATE 5/14
So I took a further look a few days back and the alternator power lead definitely is definitely pretty corroded. See pic here. A buddy of mine had some high gauge cable and large ring terminal, so I've got a cable and connector ready to go.
The remaining challenge is splicing this into the existing wire. Obviously I will cut off just before where the wire is no longer corroded, but how should I go about splicing in something that large? I have solder and a small butane torch.
The only way I can think to do this, given it's a 1 gauge wire, is to fan the wires on each end out a little and literally stick them together, meshing together. I don't think twisting would work with wire this large. Then, smush them together, use the butane torch on one side of the wire to heat it, and solder on the other. Anyone have experience soldering wire this large?
Another thought could be to use a coupler like this: http://cgi.ebay.com/Stinger-1-0-Gauge-Power-Wire-Coupling-Splice-SPT8210-/400180598274
Any thoughts on the best way to approach this? I really want to make sure this connection will be solid.
Original Post:
A few weeks ago the battery on my fiancee's 2000 Nissan Altima drained unexpectedly. She got it home and I found that where the power cable attaches to the alternator, everything was discolored and fused from apparent overheating. When I tried to take the nut off, the alternator stud just broke off. I replaced the alternator, figuring it was just defective.
Now it's happened again. I don't know how fused it is, but I drove the car home and when I wanted to re-start it to move it in the garage, it wouldn't start. Battery was at ~11.7 volts and yep, the red cap over the alternator power connection was burned through even more. The nut/stud connection looks the same as before, though perhaps not as bad.
A little googling shows that either excessive current is being drawn via a short or that a problem in the connection or battery cable is causing high resistance and burning up the nut & bolt connection.
Here's a pic I shot of it: Link
The alternator is from Advance Auto and I believe is a remanufactured one, as is common. The alternator that was on there the first time was the same type. Her OEM alternator developed a bearing whine and I replaced it. The car has less than 2000 miles on it since the first replacement.
My plan is to see how bad the power connection is and hopefully the alternator stud is still usable. I will clean the shit out of those connections, make sure shiny/clean bare metal is there. Then I will inspect the alternator power wire and see if there's anywhere that could be problematic with it.
Some other sites suggest checking for shorts & check your fuses, but I have no electrical issues so I don't see why this is pertinent.
Lastly, I noticed while driving her car a couple times that when we parked it I could smell something like brakes burning. I couldn't note the smell down to anything specific and the brakes appeared fine. I'm guessing this burning the insulating cap was that smell.
Is there anything else I should check? Any other suggestions?
Original Post:
 Facebook
Facebook Twitter
Twitter
