Alright guys, Bottom of the 9th and I need your help!
Matt2
Ok, it's like this, I just put together my new system, specs are as follows:
Intel P4 2.4B
Albatron PX845PEV PRO
512mb PC2700 DDR RAM
80GB ATA/100 Maxtor HD
GeForce 4 Ti4400
Ok, I installed windows 98.
Here's the problem. Right before it loads completely, I get this error:
"General Protection Fault. Windows failed to load driver "ndis".
You Must Restart Computer
Windows XP works fine, but I cant use it because it's not my copy so I cant activate it and I'd rather not get a visit from Microsoft.
Any ideas on what I can do to get Win98 to load? BIOS settings?
Thanks, matt!
OH MY GOD YOU DO NOT KNOW HOW F*CKING PISSED I AM!!!!!!!!!!!!!!!!!
They dont make that fix available unless you call? And the hours are only 3pm - 6pm PST???!!!!
God I hate Microsoft!!! You do not know who much I wanted to get this system working!!!!
Thanks a TON mechBgon, you hit the prob square, I owe you dude.
Glad I could help, sorry it's not a quick fix 🙁 You might PM Duvie, I know he's had to dance around this bug with his overclocked P4 rigs and maybe he has the fix, if it's a patch of some kind.
edit: can you underclock it to the 400MHz bus for starters...? 1800MHz is better than nothing.
Wow, you're quick 😀 As I mentioned above in my edit, what about underclocking to the 400MHz bus for 1800MHz to start with? Will the board let you do that?
I dont know, the P4 box is sitting unplugged in the living room so I wouldnt kick it! 🙂
I am posting from my AMD box. Thanks for the tip though, I might try that.
I sent him the file!!! All should be fine and he can get back to the duty of overclocking the piss out of that thing!!!
