Alpha: PEP66 vs PAL6035, difference other than fan location?
Noriaki
13,640
Is there a difference on these heatsinks besides one having the fan on the side and having it on top?
Trying to decide on a heatsink for a socketA chip...26CFM YSTech fan will be used either way. The 38cfm delta is out...
mechBgon
Oct 31, 1999
30,699
The PEP66 has flat fins and the PAL6035 has pin fins. The YSTech fan is a nice choice. Both heatsinks are among the best you can get for SocketA.
Supradude
1,727
the PEP has more fins too... basically just a better fin design on the PEP, hence the slight performance edge
