.... and what is the difference between the two different kinds of fans you can get on em? I found a site here in Canada that sells all sorts of great stuff for hardware/overclock junkies.. anyways.. I can get one with the YS tech fan or the Delta.... which is quieter, which has a higher CFM rating?... also, what is the difference between the 6035 and the Pep66? Is the Pep66 better, and will it fit on my A7V? Thanks..Mikewarrior? you around?
