Originally posted by: Wingznut
I'll bet that you wouldn't notice a difference at all (between lapped and not lapped.)
Ok, you got me there!Originally posted by: LED
Sure you do...if not by a couple C's then by looks![]()
Originally posted by: RalfHutter
This guy lapped his 8942 to the best finish I've ever seen and had no improvement in temps. That's been my experience with any decent heatsink as well. The 8942's have quiet good finishes on then, right out of the box. Those "curves" you see are fly-cutter marks from the milling machine. They won't affect your temps at all.
If you are serious, you are also SERIOUSLY overreacting. I can all but guarantee that lapping a high quality heatsink (such as the Alpha) will have zero effect. Heck, I'd stake the same claim on the Intel retail heatsink, and probably 90%+ of the rest of the P4 heatsinks out there...Originally posted by: Blain
Yes, all heatsinks need a good lapping before you install them... PERIOD![]()
Originally posted by: Yourself
There is a LOT of copper there, copper is soft and prone to scratches, gouges and grooves. I lap mine about every 5th or 6th install.
Self
I just bought an 8942 today, will install on 4/17/03. Do you recommend using artic silver between the HS and CPU? Or just screw it in tight?
